I’m currently in the process of porting LVGL to an STM32H743II and keep facing a hang -> infinite loop within the lvgl_task_handler function.
STM32H743II with an LTDC RGB Display.
I just want to get LVGL running on this board. I know other individuals have achieved this for the H7 but no ports or examples exist.
Following the porting guide and suggestions from other forum postings.
I’ve kept all the code within the main for now as to avoid include/pathing errors until I get this functional.
and ```
tags:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "../American_Wasteland.h"
#include "../mainCap.h"
#include "../lvgl/lvgl.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
LTDC_LayerCfgTypeDef pLayerCfg = {0};
* DEFINES
/* DMA Stream parameters definitions. You can modify these parameters to select
a different DMA Stream and/or channel.
But note that only DMA2 Streams are capable of Memory to Memory transfers. */
#define DMA_STREAM DMA2_Stream0
#define DMA_CHANNEL 0x00000000U;
#define DMA_STREAM_IRQ DMA2_Stream0_IRQn
#define DMA_STREAM_IRQHANDLER DMA2_Stream0_IRQHandler
#if TFT_NO_TEARING
#define ZONES 4 /*Divide the screen into zones to handle tearing effect*/
#else
#define ZONES 1
#define VSYNC OTM8009A_800X480_VSYNC
#define VBP OTM8009A_800X480_VBP
#define VFP OTM8009A_800X480_VFP
#define VACT OTM8009A_800X480_HEIGHT
#define HSYNC OTM8009A_800X480_HSYNC
#define HBP OTM8009A_800X480_HBP
#define HFP OTM8009A_800X480_HFP
#define HACT (OTM8009A_800X480_WIDTH / ZONES)
#define LAYER0_ADDRESS (uint32_t)&image_data_American_Wasteland
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
LTDC_HandleTypeDef hltdc;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
void SystemClock_Config(void);
static void MX_LTDC_Init(void);
/* USER CODE BEGIN PFP */
static void CPU_CACHE_Enable(void);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
extern LTDC_HandleTypeDef hltdc_discovery;
#if LV_COLOR_DEPTH == 16
static uint16_t * my_fb = (uint16_t *)LAYER0_ADDRESS;
#else
static uint32_t * my_fb = (uint32_t *)LAYER0_ADDRESS;
static DMA_HandleTypeDef DmaHandle;
static volatile int32_t x1_flush;
static volatile int32_t y1_flush;
static volatile int32_t x2_flush;
static volatile int32_t y2_flush;
static volatile int32_t y_flush_act;
static volatile const lv_color_t * buf_to_flush;
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
CPU_CACHE_Enable();
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
MX_GPIO_Init();
MX_LTDC_Init();
tft_init();
lv_ex_get_started_1();
/* USER CODE END SysInit */
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
lv_task_handler();
HAL_Delay(5);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
/** Supply configuration update enable
HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
/** Configure the main internal regulator output voltage
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
/** Macro to configure the PLL clock source
__HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSI);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_DIV1;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
|RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV1;
RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
PeriphClkInitStruct.PLL3.PLL3M = 32;
PeriphClkInitStruct.PLL3.PLL3N = 129;
PeriphClkInitStruct.PLL3.PLL3P = 2;
PeriphClkInitStruct.PLL3.PLL3Q = 2;
PeriphClkInitStruct.PLL3.PLL3R = 2;
PeriphClkInitStruct.PLL3.PLL3RGE = RCC_PLL3VCIRANGE_1;
PeriphClkInitStruct.PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE;
PeriphClkInitStruct.PLL3.PLL3FRACN = 0;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
Error_Handler();
* @brief LTDC Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN LTDC_Init 0 */
/* USER CODE END LTDC_Init 0 */
/* USER CODE BEGIN LTDC_Init 1 */
/* USER CODE END LTDC_Init 1 */
hltdc.Instance = LTDC;
hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
hltdc.Init.HorizontalSync = 7;
hltdc.Init.VerticalSync = 3;
hltdc.Init.AccumulatedHBP = 14;
hltdc.Init.AccumulatedVBP = 5;
hltdc.Init.AccumulatedActiveW = 1040;
hltdc.Init.AccumulatedActiveH = 600;
hltdc.Init.TotalWidth = 1100;
hltdc.Init.TotalHeigh = 603;
hltdc.Init.Backcolor.Blue = 255;
hltdc.Init.Backcolor.Green = 0;
hltdc.Init.Backcolor.Red = 255;
if (HAL_LTDC_Init(&hltdc) != HAL_OK)
Error_Handler();
pLayerCfg.WindowX0 = 0;
pLayerCfg.WindowX1 = 1040;
pLayerCfg.WindowY0 = 0;
pLayerCfg.WindowY1 = 206;
pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
pLayerCfg.Alpha = 255;
pLayerCfg.Alpha0 = 0;
pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_PAxCA;
pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_PAxCA;
pLayerCfg.FBStartAdress = LAYER0_ADDRESS;
pLayerCfg.ImageWidth = 479;
pLayerCfg.ImageHeight = 206;
pLayerCfg.Backcolor.Blue = 0;
pLayerCfg.Backcolor.Green = 0;
pLayerCfg.Backcolor.Red = 255;
if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN LTDC_Init 2 */
//pLayerCfg.FBStartAdress = (uint32_t)&image_data_test_image;
/* USER CODE END LTDC_Init 2 */
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOE_CLK_ENABLE();
__HAL_RCC_GPIOI_CLK_ENABLE();
__HAL_RCC_GPIOF_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
/*Configure GPIO pin : PB5 */
GPIO_InitStruct.Pin = GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* Enable I-Cache */
SCB_EnableICache();
/* Enable D-Cache */
SCB_EnableDCache();
static void tft_flush_cb(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
// lv_disp_flush_ready(drv);
// return;
SCB_CleanInvalidateDCache();
int32_t act_x2 = area->x2 > LV_HOR_RES - 1 ? LV_HOR_RES - 1 : area->x2;
int32_t act_y2 = area->y2 > LV_VER_RES - 1 ? LV_VER_RES - 1 : area->y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_flush = act_y2;
y_flush_act = act_y1;
buf_to_flush = color_p;
/*Use DMA instead of DMA2D to leave it free for GPU*/
HAL_StatusTypeDef err;
err = HAL_DMA_Start_IT(&DmaHandle,(uint32_t)buf_to_flush, (uint32_t)&my_fb[y_flush_act * LV_HOR_RES + x1_flush],
(x2_flush - x1_flush + 1));
if(err != HAL_OK)
while(1); /*Halt on error*/
void tft_init(void){
DMA_Config();
static lv_color_t buf[LV_HOR_RES_MAX * LV_VER_RES_MAX / 10]; /*Declare a buffer for 1/10 screen size*/
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX / 10); /*Initialize the display buffer*/
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.flush_cb = tft_flush_cb; /*Set your driver function*/
disp_drv.buffer = &disp_buf; /*Assign the buffer to the display*/
lv_disp_drv_register(&disp_drv); /*Finally register the driver*/
static void DMA_TransferComplete(DMA_HandleTypeDef *han)
y_flush_act ++;
if(y_flush_act > y2_flush) {
SCB_InvalidateICache();
lv_disp_flush_ready(&disp_drv);
} else {
uint32_t length = (x2_flush - x1_flush + 1);
buf_to_flush += x2_flush - x1_flush + 1;
/*##-7- Start the DMA transfer using the interrupt mode ####################*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
#if LV_COLOR_DEPTH == 24 || LV_COLOR_DEPTH == 32
length *= 2; /* STM32 DMA uses 16-bit chunks so multiply by 2 for 32-bit color */
if(HAL_DMA_Start_IT(han,(uint32_t)buf_to_flush, (uint32_t)&my_fb[y_flush_act * LV_HOR_RES + x1_flush],
length) != HAL_OK)
static void DMA_TransferError(DMA_HandleTypeDef *han)
void DMA_Config(void)
/*## -1- Enable DMA2 clock #################################################*/
__HAL_RCC_DMA2_CLK_ENABLE();
/*##-2- Select the DMA functional Parameters ###############################*/
DmaHandle.Init.Channel = DMA_CHANNEL; /* DMA_CHANNEL_0 */
DmaHandle.Init.Direction = DMA_MEMORY_TO_MEMORY; /* M2M transfer mode */
DmaHandle.Init.PeriphInc = DMA_PINC_ENABLE; /* Peripheral increment mode Enable */
DmaHandle.Init.MemInc = DMA_MINC_ENABLE; /* Memory increment mode Enable */
DmaHandle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; /* Peripheral data alignment : 16bit */
DmaHandle.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; /* memory data alignment : 16bit */
DmaHandle.Init.Mode = DMA_NORMAL; /* Normal DMA mode */
DmaHandle.Init.Priority = DMA_PRIORITY_HIGH; /* priority level : high */
DmaHandle.Init.FIFOMode = DMA_FIFOMODE_ENABLE; /* FIFO mode enabled */
DmaHandle.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_1QUARTERFULL; /* FIFO threshold: 1/4 full */
DmaHandle.Init.MemBurst = DMA_MBURST_SINGLE; /* Memory burst */
DmaHandle.Init.PeriphBurst = DMA_PBURST_SINGLE; /* Peripheral burst */
/*##-3- Select the DMA instance to be used for the transfer : DMA2_Stream0 #*/
DmaHandle.Instance = DMA_STREAM;
/*##-4- Initialize the DMA stream ##########################################*/
if(HAL_DMA_Init(&DmaHandle) != HAL_OK)
while(1)
/*##-5- Select Callbacks functions called after Transfer complete and Transfer error */
HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_CPLT_CB_ID, DMA_TransferComplete);
HAL_DMA_RegisterCallback(&DmaHandle, HAL_DMA_XFER_ERROR_CB_ID, DMA_TransferError);
/*##-6- Configure NVIC for DMA transfer complete/error interrupts ##########*/
HAL_NVIC_SetPriority(DMA_STREAM_IRQ, 0, 0);
HAL_NVIC_EnableIRQ(DMA_STREAM_IRQ);
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Screenshot of the error I receive.
