Hello everyone,
I am trying to port lvgl to a 240x128 resistive touch display. I already have a simpler graphic library and drivers running on my device so the task should not be particularly hard.
I have been taking this tutorial as reference: https://blog.littlevgl.com/2019-05-06/oled
Here however I find some discrepancies between the official API and the code snippets. Specifically it seems to reference the special case for a monochrome display that I can’t find in the source code of the library.
The code I’m referring to is the following:
monitor_init();
lv_disp_drv_t disp_drv;
disp_drv.disp_flush = monitor_flush;
disp_drv.vdb_wr = lv_vdb_wr_gray;
Here it uses the fields disp_flush and vdb_wr of the lv_disp_driver_t structure: in the official API however the former just doesn’t exist and the latter is called flush_cb instead…
I believe the functionalities used should have been implemented 1 year ago in the wake of this Github issue https://github.com/littlevgl/lvgl/issues/300, which mention version 5.2 ; the latest lvgl version is 6.0, so it should be there?
I’m a little confused, can someone clarify this for me?
