Porting LVGL to a monochrome display
I’m using LVGL for a proprietary application running on a POS device. The device is really small (100MHz CPU, 384KB RAM, 8MB Flash). It has a small 128x64 monochrome display and the API is just a PutPixel(x, y, color).
I read the porting guide and implemented a driver like this one:
void
display_flush(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_p)
pwInt32 x, y;
const pwInt32 startX = area->x1;
const pwInt32 startY = area->y1;
const pwInt32 endX = area->x2;
const pwInt32 endY = area->y2;
for( x = startX; x < endX; ++x )
for( y = startY; y < endY; ++y )
uchar dot = (uchar)lv_color_to1( *color_p );
ScrPlot( x, y, dot );
color_p++;
lv_disp_flush_ready(drv);
For testing, I got this simple code from the manual:
void lv_example_label_1(void)
lv_obj_t * label1 = lv_label_create(lv_scr_act());
lv_label_set_long_mode(label1, LV_LABEL_LONG_WRAP);
lv_label_set_text(label1, "Hello LVGL!");
lv_obj_set_width(label1, 64); /*Set smaller width to make the lines wrap*/
lv_obj_set_style_text_align(label1, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(label1, LV_ALIGN_CENTER, 0, -40);
Also, the code that initializes the driver and registers it is this one (DRAW_BUFFER_SIZE=1024):
static void D175_diplay_init_driver_( void )
static lv_disp_draw_buf_t displayDrawBuffer_;
static lv_color_t buffer_[DRAW_BUFFER_SIZE];
static lv_disp_drv_t displayDriver_;
lv_disp_draw_buf_init( &displayDrawBuffer_, buffer_, NULL,
DRAW_BUFFER_SIZE );
lv_disp_drv_init( &displayDriver_ );
displayDriver_.hor_res = LV_HOR_RES_MAX;
displayDriver_.ver_res = LV_VER_RES_MAX;
displayDriver_.flush_cb = D175_display_flush;
displayDriver_.draw_buf = &displayDrawBuffer_;
display_ = lv_disp_drv_register( &displayDriver_ );
Now, I’m getting this drawn in my screen:
Could you please, help me figure out what I’m doing wrong?
