Porting from stm32f7 to stm32h7
I have a board where the STM32F7 micro was replaced with an STM32H7. I ported it and the display works. It turns on and displays the home page correctly, but I can’t update the display. The callback to update the frame fires only once. How can I fix this?
With the same code it obviously works on STM32F7
void lv_port_disp_init()
	disp_init();
	lv_port_fs_init();
	Init_IconFonts();
	Init_TextFont(font);
	__HAL_LTDC_ENABLE_IT(&hltdc, LTDC_IT_RR);
//	HAL_GPIO_WritePin(UD_uC_GPIO_Port, UD_uC_Pin, GPIO_PIN_SET);
	/*Create a display and set a flush_cb */
	lv_display_t * disp = lv_display_create(MY_DISP_HOR_RES, MY_DISP_VER_RES);
	lv_display_set_flush_cb(disp, disp_flush);
	lv_display_set_rotation(disp, LV_DISPLAY_ROTATION_180);
	lv_display_set_buffers(disp, FRAMEBUFFER1_ADDR, FRAMEBUFFER2_ADDR, 800 * 480 * 2 , LV_DISPLAY_RENDER_MODE_DIRECT); //
	CreateScreen();
static void disp_init() /*Initialize your display and the required peripherals.*/
	LCD_Startup_Sequence();
volatile bool disp_flush_enabled = true;
void disp_enable_update() /* Enable updating the screen (the flushing process) when disp_flush() is called by LVGL */
void disp_disable_update() /* Disable updating the screen (the flushing process) when disp_flush() is called by LVGL  */
  disp_flush_enabled = false;
/*Flush the content of the internal buffer the specific area on the display.
 *`px_map` contains the rendered image as raw pixel map and it should be copied to `area` on the display.
 *You can use DMA or any hardware acceleration to do this operation in the background but
 *'lv_display_flush_ready()' has to be called when it's finished.*/
//static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map)
//	if(disp_flush_enabled)
//		LTDC_Layer1->CFBAR = (uint32_t)px_map;
//		LTDC->SRCR = LTDC_SRCR_IMR; // Reload immediato
//	//lv_display_flush_ready(disp_drv);
static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map) /* Funzione di flush LVGL */
	if(px_map == NULL) return;
	pending_buf = px_map;
	disp_ref = disp_drv;
	LTDC_Layer1->CFBAR = (uint32_t)pending_buf;
	LTDC->SRCR = LTDC_SRCR_VBR;
 * IRQ handler per LTDC
 * Deve essere chiamato da LTDC_IRQHandler
void LTDC_ReloadEventCallback()
	if(disp_ref != NULL)
		lv_display_flush_ready(disp_ref);
//		HAL_GPIO_TogglePin(Check_Display_GPIO_Port, Check_Display_Pin);
		disp_ref = NULL;  // Reset, attendo un nuovo flush
  • MCU/MPU/Board: STM32H743
  • LVGL version: 9.3.0
