Points_array in indev_button
I am currently facing an issue with using array of point in indev_button implementations
i am using a esp32s3 M5Dial
8.3
So as M5Dial has 1 inbuilt button(encoder button ) i want to use the button for navigation. The event of shortpress and longpress. The problem is when i pass the array of points it only simulates the 1st index and doesnt take the other ones. Is there something i am missing or is there another way to do the longpress event.
I have tried giving it the complete array, but since it is not takking the first value i have constantly update the 1st index and do a workaround through that
static lv_point_t btn_points[2] ;
static int8_t button_get_pressed_id_1(void) {
  // Check if the button on the M5Dial is pressed
  if (M5.BtnA.isPressed()) {
    return 0; // The button is pressed, return button ID as 0
  return -1;// No button is pressed
void button_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data) {
  static uint8_t last_btn = 0;   /*Store the last pressed button*/
  int8_t btn_act = button_get_pressed_id_1();    /*Get the ID (0,1,2...) of the pressed button*/
  if (btn_act >= 0) {              /*Is there a button press? (E.g. -1 indicated no button was pressed)*/
    last_btn = btn_act;           /*Save the ID of the pressed button*/
    data->state = LV_INDEV_STATE_PR;  /*Set the pressed state*/
  } else {
    data->state = LV_INDEV_STATE_REL; /*Set the released state*/
  data->btn_id = last_btn;  /*Save the last button*/
if (params_mode) {
    lv_indev_set_group(encoder_indev, groups.params_nav);
    lv_indev_set_group(touch_indev, groups.params_nav);
    lv_indev_set_group(button_indev, groups.params_nav);
    if (millis() - lastPressTime > timeout_duration) {
      if (!isBlinking) {
        btn_points[0].x = 63;
        btn_points[0].y = 186;
        updateLEDs(0, 0, 0, 33, 131, 146, 0, 0, 0);
      } else {
        btn_points[0].x = 121;
        if (blink) {
          updateLEDs(0, 0, 0, 0, 0, 0, 0, 0, 0);  // Turn off LEDs
        } else {
          updateLEDs(0, 0, 0, 0, 0, 255, 0, 0, 0); // Turn on LED 7
      lastPressTime = millis(); // Update the last press time
  } else {
    // When not in params_mode and not blinking
    if (!isBlinking) {
      lv_indev_set_group(encoder_indev, groups.main_nav);
      lv_indev_set_group(touch_indev, groups.main_nav);
      lv_indev_set_group(button_indev, groups.main_nav);
      updateLEDs(0, 0, 0, 100, 0, 0, 0, 0, 0);
      btn_points[0].x = 120;
      btn_points[0].y = 120;
this is functional but i want to add another coordinate
i have tried
btn_points{1].x = 110;
btn_points[1].y = 10;
but doesnt work
in documention there is a mention of this
const lv_point_t points_array[] = { {12,30},{60,90}, ...}
i wonder if i am using the same thing or not
In case your button_indev initialized as LV_INDEV_TYPE_BUTTON type your button_read() should define ID of pressed button and store it in data->btn_id. Your button_read() could define only one id equal 0. So only first item of btn_points with index 0 will be used.
If you want to use next item of btn_points your button_read() should define data->btn_id = 1
Hello @glory-man thankk you for the reply,
i tried your solution which works properly but it is isnt practical in my situation as there are 2 buttons on the same screen and under the same flag, the only thing that differentiates them is a long press and short press. is it possible to simulate two buttons on the same screen?
If your buttons has the same position only one of them will be active (on the top layer). In this case you can use only one button and handle appropriate events associated with it (LV_EVENT_SHORT_CLICKED, LV_EVENT_LONG_PRESSED, LV_EVENT_CLICKED).
