lv_obj_t *obj = lv_img_create(parent_obj);
objects.transparent_test2 = obj;
lv_obj_set_pos(obj, 100, 5);
lv_obj_set_size(obj, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
lv_img_set_src(obj, "S:/PNG/wink.png");
I use LVGL 8.4 and the cheap yellow display
This is my Code in screen.c
The Logging shows this
load:0x40078000,len:13232
load:0x40080400,len:3028
entry 0x400805e4
[Info] (0.346, +346) lv_init: begin (in lv_obj.c line #106)
[Info] (0.349, +3) lv_obj_create: begin (in lv_obj.c line #215)
[Info] (0.351, +2) lv_obj_create: begin (in lv_obj.c line #215)
[Info] (0.353, +2) lv_obj_create: begin (in lv_obj.c line #215)
[Info] (0.360, +7) lv_obj_create: begin (in lv_obj.c line #215)
[Info] (0.365, +5) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.372, +7) lv_img_create: begin (in lv_img.c line #60)
[Info] (0.377, +5) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.386, +9) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.393, +7) lv_img_create: begin (in lv_img.c line #60)
[Info] (0.398, +5) lv_img_create: begin (in lv_img.c line #60)
[Info] (0.404, +6) lv_img_create: begin (in lv_img.c line #60)
[Info] (0.411, +7) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.417, +6) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.425, +8) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.477, +52) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #314)
[Info] (0.500, +23) _lv_img_cache_open: image draw: cache miss, cached to an empty entry (in lv_img_cache.c line #116)
[Info] (0.525, +25) _lv_img_cache_open: image draw: cache miss, close and reuse an entry (in lv_img_cache.c line #113)
[Info] (0.579, +54) _lv_img_cache_open: image draw: cache miss, close and reuse an entry (in lv_img_cache.c line #113)
[Info] (0.604, +25) _lv_img_cache_open: image draw: cache miss, close and reuse an entry (in lv_img_cache.c line #113)
[Info] (0.654, +50) _lv_img_cache_open: image draw: cache miss, close and reuse an entry (in lv_img_cache.c line #113)
[Info] (0.676, +22) _lv_img_cache_open: image draw: cache miss, close and reuse an entry (in lv_img_cache.c line #113)
