Please explain how to integrate LVGL into regular code?
I’m using STM32 Nucleo-H7A3 and their STM32CudeIDE
V8.3
I’d like for someone to explain or point me to information that explains how to integrate LVGL into normal code.
void calibrate(void)
	uint8_t current_index = 0;
	lv_obj_clean(lv_scr_act());
	lv_print_CAL_Test_text();
	lv_display_3_buttons();
	lv_display_target_mA_value();
	generate_CAL_current(current_index);
void lv_display_target_mA_value(void)
    ma_textarea = lv_textarea_create(lv_scr_act());
    lv_textarea_set_one_line(ma_textarea, true);
    lv_obj_set_size(ma_textarea, 155, 70);
    lv_obj_align(ma_textarea, LV_ALIGN_TOP_MID, 120, 210);
    lv_obj_add_event_cb(ma_textarea, event_handlerMA, LV_EVENT_VALUE_CHANGED, NULL);
    lv_obj_add_state(ma_textarea, LV_STATE_FOCUSED); /*To be sure the cursor is visible*/
    sprintf(MA_buf, "%.3f", target_current[ma_index]);
    lv_textarea_set_text(ma_textarea, MA_buf);
    static lv_style_t style_label;
    lv_style_init(&style_label);
    lv_style_set_text_font(&style_label, &lv_font_montserrat_36);
    lv_obj_add_style(ma_textarea, &style_label, LV_STATE_DEFAULT); /* fix order */
static void button_plus_event_handler(lv_event_t* e)
    if (code == LV_EVENT_PRESSED) {
    	LV_LOG_USER("Clicked");
    else if (code == LV_EVENT_VALUE_CHANGED) {
        LV_LOG_USER("Toggled");
    CAL_adj += 10;				// add to D/A counts to achieve target current
void generate_CAL_current(uint16_t current_index)
	uint16_t ch1Data, ch2Data, counts;
	counts = D2A_CAL_counts[current_index] + CAL_adj;
	Write_DAC80501_DAC(counts);
	HAL_Delay(5);
	readMCP3427(&ch1Data, &ch2Data);	// Read data from MCP3427 ADC
	HAL_Delay(5);
Currently the code will display the proper screen and the target current gets displayed as it should. The button_plus_event works. It increments the CAL_adj value. But how do I call the generate_CAL_current(current_index) function again? It only gets called once.
Can some kind soul point me to where the documentation covers this sort of thing?
Thanks,
Richard
Hi @rmcooke88,
I suggest you start using sujbects to integrate into your project. If you still need help integrating your project with LVGL, let me know.
