Personal experience migrating from v.8.3.x to v.9.0 in the Arduino environment
Wanted to share my personal experience migrating from one version of LVGL v.8.3.x to v.9.0 in the Arduino environment. The lines of code outlined below resolved so many unusual behaviors and issues that surfaced from the migration. I hope that the code helps others so they don’t have to spend as much time as I did to resolve these matters.
ESP32C3 + Arduino 2.2.1
v.9.0
unsigned long prior_tick_Millis=millis();
// the following is a key element required for v9.0 vs v8.x
// you must keep track of the time otherwise really odd behavior will result from the widgets and device
void handleTicks(void){
   unsigned long tickMillis = millis()-prior_tick_Millis;
  lv_tick_inc(tickMillis);
  yield();
//call the above function in the "loop" routine and at any point where you need to refresh screen.
Thanks for the hint!
Actually I’ve started today to check how to achieve this and it’s quite a big upgrade. I was a bit lost to discover that drivers is now part of the same repository.
Many others things need to be updated. If anyone has a nice guide for porting an existing project from 8 to 9 it will be a great read
In case it’s still relevant you can find a v8 to v9 migration guide here:
https://docs.lvgl.io/9.0/CHANGELOG.html#migration-guide
