So essentially I have fixed the display driver for my SSD1608 200x200 eInk panel and have got a basic monochrome button example working great. I had major problems with threading as the Arduino BSP is quite abstracted, so I had to manually port in the RTC drivers for my chip to implement a periodic timer but it is all working now.
I am now attempting to periodically update a label with the current time using an lv_timer - it calls a function every 1000ms and updates the value of the label with the current time. This works well, but I have some bizarre graphical behavior.
The part of the display which changes every second updates fine, but the other element (button) completely disappears until the next refresh. It then alternates between being shown and not being shown. If I press the button, it then starts alternating between the previous state and the current state. Please see video for detailed behavior. I suspect this may have something to do with the eInk display’s double framebuffer, essentially my display controller appears to have two different memory buffers. When I call the function to update the display, the controller toggles the framebuffer, so any memory writes affect the other framebuffer.
Perhaps the button is only being written to one framebuffer, so as the framebuffers alternate upon refresh it just disappears. This would make sense, because LVGL only sends the changed data to the display - the button state does not change and hence the alternating behavior does not stop until I press the button, which results in a different alternating sequence.
I would greatly appreciate any help I can get with working around this.
Nordic nRF52840-DK (adafruit BSP), GCC, SSD1608 200x200 eink display
8.0.1
Fix this alternating behavior
Introducing second memory buffer, playing with round_cb, enabling full_refresh in disp_drv.
Display functions:
//TODO - debug & fix for better performance
void epd_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint8_t *buf = (uint8_t*) color_p;
epd.SetFrameMemory(buf, area->x1, area->y1, area->x2 - area->x1+1, area->y2-area->y1+1);
if(lv_disp_flush_is_last(disp))
epd.MixedRefresh(7);
//epd.WaitUntilIdle();
lv_disp_flush_ready(disp);
void epd_set_px_cb(lv_disp_drv_t *disp, uint8_t *buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y, lv_color_t color, lv_opa_t opa)
unsigned char bitIndex, a;
uint16_t byteIndex = (y*(buf_w/8))+((x&0xF8)/8);
bitIndex = x-(x&0xF8);
a = 1;
if(lv_color_brightness(color) > 128)
buf[byteIndex] |= a << (7-bitIndex);
else{
buf[byteIndex] &= ~(a << (7-bitIndex));
//DEBUG AND FIX
void epd_rounder( lv_disp_drv_t *disp, lv_area_t *area)
//area->x1 = area->x1 & ~(0x7);
//area->x2 = area->x2 | 0x7;
area->x1 = 0;
area->x2 = 200;
LVGL functions:
void time_label_update_timer(lv_timer_t* timer)
RTCTime = rtc.now();
char timeBuf[25];
sprintf(timeBuf, "%02u:%02u:%02u", RTCTime.hour(), RTCTime.minute(), RTCTime.second());
lv_label_set_text(time_label, timeBuf);
static void guiTask(void *pvParameter)
(void) pvParameter;
GuiSemaphore = xSemaphoreCreateMutex();
if (epd.Init(lut_full_update) != 0) {
SEGGER_RTT_WriteString(0, "e-Paper init failure");
return;
SEGGER_RTT_WriteString(0, "e-Paper init");
epd.ClearFrameMemory(0xFF);
epd.DisplayFrame();
epd.DisplayFrame();
epd.SetLut(lut_partial_update);
digitalWrite(PIN_LED1, LOW);
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
lv_disp_draw_buf_init( &draw_buf, buf_1, NULL, screenWidth * screenHeight / 8 );
/*Initialising display*/
disp_drv.flush_cb = epd_flush;
disp_drv.set_px_cb = epd_set_px_cb;
disp_drv.rounder_cb = epd_rounder;
lv_disp_t* disp;
disp = lv_disp_drv_register( &disp_drv );
//KEYPAD Initialisation. ToDo - refactor into nice methods once eInk operational.
lv_indev_drv_init( &indev_drv );
indev_drv.type = LV_INDEV_TYPE_KEYPAD;
indev_drv.read_cb = button_reader;
//indev_drv.feedback_cb = button_feedback;
lv_indev_t* indev = lv_indev_drv_register( &indev_drv );
lv_theme_t* theme = lv_theme_mono_init(disp, false, &lv_font_montserrat_30);
lv_disp_set_theme(disp, theme);
#if 0
/* Create simple label */
lv_obj_t *label = lv_label_create( lv_scr_act() );
lv_label_set_text( label, "Hello Arduino! (V8.0.X)" );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
#else
/* Try an example from the lv_examples Arduino library
make sure to include it as written above.
lv_example_btn_1();
// uncomment one of these demos
//lv_example_btn_1(indev);
lv_watch_display(indev);
//lv_demo_widgets(); // OK
//lv_demo_benchmark(); // OK
//lv_demo_keypad_encoder(); // works, but I haven't an encoder
// lv_demo_music(); // NOK
// lv_demo_printer();
// lv_demo_stress(); // seems to be OK
//LMAO THIS DOES NOT WORK
//xTaskCreate(GUIUpdate, "LVGL", 256, NULL, tskIDLE_PRIORITY+4, &Handle_GUIUpdate);
DateTime now = rtc.now();
char date[100];
sprintf(date, "%d:%d:%d\n", now.hour(), now.minute(), now.second());
SEGGER_RTT_WriteString(0, date);
SEGGER_RTT_WriteString(0, "Setup done" );
lv_timer_t* timeUpdate = lv_timer_create(time_label_update_timer, 1000, NULL);
//date_label_update_timer(NULL);
//lv_timer_t* dateUpdate = lv_timer_create(date_label_update_timer, 4.32E7, NULL);
rtc_config();
while(1) {
delay(5);
if(pdTRUE==xSemaphoreTake(GuiSemaphore, portMAX_DELAY)){
lv_timer_handler();
xSemaphoreGive(GuiSemaphore);
void lv_watch_display(lv_indev_t* indev)
lv_group_t* g = lv_group_create();
//lv_obj_t * label;
lv_obj_t * test_btn = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(test_btn, event_handler, LV_EVENT_ALL, NULL);
lv_obj_align(test_btn, LV_ALIGN_CENTER, 0, 60);
lv_obj_add_flag(test_btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_set_height(test_btn, LV_SIZE_CONTENT);
date_label = lv_label_create(test_btn);
lv_label_set_text(date_label, "Toggle");
lv_obj_set_style_text_font(date_label, &lv_font_montserrat_10, 0);
lv_obj_center(date_label);
time_label = lv_label_create(lv_scr_act());
lv_label_set_text(time_label, "");
lv_obj_set_style_text_font(time_label, &lv_font_montserrat_48, 0);
lv_obj_align(time_label, LV_ALIGN_CENTER, 0, -40);
lv_group_add_obj(g, test_btn);
lv_indev_set_group(indev, g);
lv_scr_load(lv_scr_act());
https://www.veed.io/download/87c16402-f2ad-4afd-9bd0-83d95ee16c54
Apologies for the awful quality!
