Hello partners!
How are you? I haven’t had a problem for a few days. I will try to be as specific as possible.
I am creating a UI interface (it works correctly).
I want to add listening to advertising messages via Bluetooth (by itself it works, I listen and translate the payload correctly), in fact on a m5stick without lvgl it worked correctly.
Now I am in the problem that I have a project with a touch screen ESP32-S3 (SC01-plus), that as soon as I add pBLEScan the screen stops working.
I am creating the project with Platformio.
I am attaching relevant info, please if more information is needed to find the problem I am attaching it.
plaftormio.ini:
[env:WT32-SC01-PLUS]
platform = espressif32
board = um_tinys3
;board = esp32s3box
board_build.mcu = esp32s3
framework = arduino
upload_speed = 921600
monitor_speed = 115200
build_flags =
-DARDUINO_USB_CDC_ON_BOOT
-DLV_CONF_INCLUDE_SIMPLE
-DLV_COMP_CONF_INCLUDE_SIMPLE
-DLV_LVGL_H_INCLUDE_SIMPLE
-DCONFIG_ARDUINO_LOOP_STACK_SIZE=32768
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
-I src/ui/
-I src/
lib_deps =
SPI
Wire
lovyan03/LovyanGFX@^1.1.8
lvgl/lvgl@^8.3.7
me-no-dev/AsyncTCP@^1.1.1
arduino-libraries/ArduinoBLE@^1.2.3
;h2zero/NimBLE-Arduino@^1.4.0
board_upload.flash_size = 16MB
board_build.partitions = default_16MB.csv
main.cpp:
#define LGFX_USE_V1
#include <Arduino.h>
#include <WebServer.h>
#include <LovyanGFX.hpp>
#include “stdio.h”
#include “WiFi.h”
#include “webserver_setup.h”
#include <BLEDevice.h>
#include <BLEAdvertisedDevice.h>
#include <Wire.h>
BLEScan* pBLEScan;
// Crear una instancia de WebServer
//WebServer server(80);
void decodePayload(const uint8_t* payload, size_t payloadLength) {
if (payloadLength < 5) {
return;
if (payload[0] != 0x52 || payload[1] != 0x41 || payload[2] != 0x50 || payload[3] != 0x54 || payload[4] != 0x02) {
return;
uint16_t rawTemperature = (payload[11] << 8) | payload[12];
float temperature = (float)(rawTemperature / 128.0 - 273.15);
union FloatIntUnion {
uint32_t i;
float f;
FloatIntUnion data;
data.i = (payload[13] << 24) | (payload[14] << 16) | (payload[15] << 8) | payload[16];
float gravity = data.f;
uint8_t batteryPercentage = *(payload + 23);
Serial.printf(“Temp: %.2f C\n”, temperature);
Serial.printf(“Gravedad: %.3f\n”, gravity);
Serial.printf(“Bateria: %d %%\n”, batteryPercentage);
Serial.print("Payload sin tratar: “);
for(int i = 0; i < payloadLength; i++){
Serial.print(payload[i], HEX);
Serial.print(” ");
Serial.println();
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
void onResult(BLEAdvertisedDevice advertisedDevice) {
std::string manufacturerData = advertisedDevice.getManufacturerData();
const uint8_t* payload = (const uint8_t*)manufacturerData.c_str();
size_t payloadLength = manufacturerData.length();
decodePayload(payload, payloadLength);
Serial.print("MAC del dispositivo: ");
Serial.println(advertisedDevice.getAddress().toString().c_str());
void setupBluetooth() {
BLEDevice::init(“AllBrewSensors”);
BLEScan* pBLEScan = BLEDevice::getScan();
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setActiveScan(false);
// SETUP LGFX PARAMETERS FOR WT32-SC01-PLUS
class LGFX : public lgfx::LGFX_Device
lgfx::Panel_ST7796 _panel_instance;
lgfx::Bus_Parallel8 _bus_instance;
lgfx::Light_PWM _light_instance;
lgfx::Touch_FT5x06 _touch_instance; // FT5206, FT5306, FT5406, FT6206, FT6236, FT6336, FT6436
public:
LGFX(void)
auto cfg = _bus_instance.config();
cfg.freq_write = 20000000;
cfg.pin_wr = 47; // pin number connecting WR
cfg.pin_rd = -1; // pin number connecting RD
cfg.pin_rs = 0; // Pin number connecting RS(D/C)
cfg.pin_d0 = 9; // pin number connecting D0
cfg.pin_d1 = 46; // pin number connecting D1
cfg.pin_d2 = 3; // pin number connecting D2
cfg.pin_d3 = 8; // pin number connecting D3
cfg.pin_d4 = 18; // pin number connecting D4
cfg.pin_d5 = 17; // pin number connecting D5
cfg.pin_d6 = 16; // pin number connecting D6
cfg.pin_d7 = 15; // pin number connecting D7
//cfg.i2s_port = I2S_NUM_0; // (I2S_NUM_0 or I2S_NUM_1)
_bus_instance.config(cfg); // Apply the settings to the bus.
_panel_instance.setBus(&_bus_instance); // Sets the bus to the panel.
{ // Set display panel control.
auto cfg = _panel_instance.config(); // Get the structure for display panel settings.
cfg.pin_cs = -1; // Pin number to which CS is connected (-1 = disable)
cfg.pin_rst = 4; // pin number where RST is connected (-1 = disable)
cfg.pin_busy = -1; // pin number to which BUSY is connected (-1 = disable)
// * The following setting values are set to general default values for each panel, and the pin number (-1 = disable) to which BUSY is connected, so please try commenting out any unknown items.
cfg.memory_width = 320; // Maximum width supported by driver IC
cfg.memory_height = 480; // Maximum height supported by driver IC
cfg.panel_width = 320; // actual displayable width
cfg.panel_height = 480; // actual displayable height
cfg.offset_x = 0; // Panel offset in X direction
cfg.offset_y = 0; // Panel offset in Y direction
cfg.offset_rotation = 0; // was 2
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = true; // was false
cfg.invert = true;
cfg.rgb_order = false;
cfg.dlen_16bit = false;
cfg.bus_shared = true; // was false something to do with SD?
_panel_instance.config(cfg);
{ // Set backlight control. (delete if not necessary)
auto cfg = _light_instance.config(); // Get the structure for backlight configuration.
cfg.pin_bl = 45; // pin number to which the backlight is connected
cfg.invert = false; // true to invert backlight brightness
cfg.freq = 44100; // backlight PWM frequency
cfg.pwm_channel = 0; // PWM channel number to use (7??)
_light_instance.config(cfg);
_panel_instance.setLight(&_light_instance); // Sets the backlight to the panel.
{ // Configure settings for touch screen control. (delete if not necessary)
auto cfg = _touch_instance.config();
cfg.x_min = 0; // Minimum X value (raw value) obtained from the touchscreen
cfg.x_max = 319; // Maximum X value (raw value) obtained from the touchscreen
cfg.y_min = 0; // Minimum Y value obtained from touchscreen (raw value)
cfg.y_max = 479; // Maximum Y value (raw value) obtained from the touchscreen
cfg.pin_int = 7; // pin number to which INT is connected
cfg.bus_shared = false; // set true if you are using the same bus as the screen
// For I2C connection
cfg.i2c_port = 0; // Select I2C to use (0 or 1)
cfg.i2c_addr = 0x38; // I2C device address number
cfg.pin_sda = 6; // pin number where SDA is connected
cfg.pin_scl = 5; // pin number to which SCL is connected
cfg.freq = 400000; // set I2C clock
_touch_instance.config(cfg);
_panel_instance.setTouch(&_touch_instance); // Set the touchscreen to the panel.
setPanel(&_panel_instance); // Sets the panel to use.
#include <lvgl.h>
#include “ui/ui.h” // this is the ui generated with lvgl / squareline editor
#include “ui_panel1.h”
#include “ui_sensores1.h”
#include “ui_densidad1.h”
#include “ui_graficas1.h”
//#include “ui_ajustes1.h”
//#include “ui_raptpill.h”
//#include “ui_ispindel.h”
//#include “ui_tilth.h”
LGFX tft;
#define screenWidth 480
#define screenHeight 320
// lv debugging can be set in lv_conf.h
//#if LV_USE_LOG != 0
/* Serial debugging */
//void my_print(const char * buf)
// Serial.printf(buf);
// Serial.flush();
//#endif
// create buffer for display
static lv_color_t buf[screenWidth * 10];
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
tft.startWrite();
tft.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
tft.endWrite();
lv_disp_flush_ready(disp);
/Read the touchpad/
void my_touch_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) {
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY);
if (!touched) { data->state = LV_INDEV_STATE_REL; }
else {
data->point.x = touchX;
data->point.y = touchY;
#if DEBUG_TOUCH !=1
Serial.print( "Data x " ); Serial.println( touchX );
Serial.print( "Data y " ); Serial.println( touchY );
void setupTouchscreen() {
tft.begin();
tft.setRotation(3);
tft.setBrightness(255);
// lv_log_register_print_cb( my_print ); /* register print function for debugging */
//#endif
lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * 10);
/Initialize the display/
lv_disp_drv_init(&disp_drv);
/Initialize the input device driver/
indev_drv.read_cb = my_touch_read;
void setup() {
Serial.begin(115200);
setupTouchscreen();
ui_init();
setupBluetooth();
void loop() {
pBLEScan->start(120);
delay(5);
pBLEScan->stop();
lv_timer_handler();
delay(5);
