I have adapted the lv_demo_printer() example and it is called from and Arduino.ino file. In this I have created a task that runs every 10 seconds and should update the gui based on incoming sensor readings.
The problem is that when I update a variable value in the main arduino loop, when the task is ran by lv_task_gandler() it only reverences varables which are in the lv_demo_printer.c file and does not take te updated value from the Arduino.ino file.
ESP32 ILI9488
7.8
access values updated from arduino loop into lv_demo_printer.c to change GUI items.
so if you look at the code below and you called the lv_printer_example from lv_examples, how would you use the globalCounter value to determine GUI changes. This probably c 101 but I am stick so please help!
using extern in the lv_demo_printer.c file but when I call the variable values the updated value is not used.
I have created a task within lv_demo_printer, which runs, but when It tries to take the value set in the loop it does not pick up the value.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <lv_examples.h>
// #include <lv_demo_printer.c>
// #include <lv_examples.h>
#include <Ticker.h>
static int globalCounter = 0; // I WANT TO USE THIS VALUE GLOBALY
static String LoRaData;
#define screenWidth 480
#define screenHeight 320
#define LVGL_TICK_PERIOD 20
Ticker lvgl_tick; /* timer for lvgl */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(lv_log_level_t level, const char * file, uint32_t line, const char * fn_name, const char * dsc)
Serial.printf("%[email protected]%d->%s\r\n", file, line, dsc);
Serial.flush();
/* Display flushing */
tft.startWrite();
tft.pushColors(&color_p->full, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
/*Read the touchpad*/
bool my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 600);
if (!touched)
return false;
if (touchX > screenWidth || touchY > screenHeight)
Serial.println("Y or y outside of expected parameters..");
Serial.print("y:");
Serial.print(touchX);
Serial.print(" x:");
Serial.print(touchY);
/*Set the coordinates*/
if (3 == tft.getRotation()) {
//Shift coordinates
data->point.x = 480 - touchX;
data->point.y = 320 - touchY;
} else if (1 == tft.getRotation()) {
data->point.x = touchX;
data->point.y = touchY;
Serial.print("Data x");
Serial.println(touchX);
Serial.print("Data y");
Serial.println(touchY);
return false; /*Return `false` because we are not buffering and no more data to read*/
void lv_tick_handler() {
void setup()
#if LV_USE_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation */
// uint16_t calData[5] = { 305, 3542, 245, 3529, 3 };
uint16_t calData[5] = { 270, 3639, 250, 3556, 7 };
tft.setTouch(calData);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 480;
disp_drv.ver_res = 320;
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
lvgl_tick.attach_ms(LVGL_TICK_PERIOD, lv_tick_handler);
lv_demo_printer();
void loop()
delay(5);
globalCounter++;
