I have objects that are disabled, and they don’t receive touch events. This works as should be, but sometimes I would need some elements to receive events. For example, if something is disabled and is touched, raise a popup explaining how to enable it.
In line 872 of lv_indev I have tried disabling the line
and now all the disabled objects receive the events. But I think the best would be a property where you can set if the event is passed (in case of disabled) or not, set by default to off.
I think the current method is valid for almost all cases, so it is correct. But for some cases, it should be possible to change it. Like when you change lv_obj_set_click on a label, for example.
Actually, I have just modified the code, adding a variable like click in the obj definition, and a pair of functions, and now I can modify this behaviour whenever I want
I will try to make a commit when possible, to see if it makes sense.
