One-shot GIF support
Is there a way to stop the looping behaviour of a GIF widget? I’ve converted a file to a RAW buffer using the online image converter and the GIF is showed correctly, however I would like it to stop on the last frame after the first loop. Is there a way to achieve this?
Custom board with a STM32H753
Latest v8.3 branch revision
I solved it by exporting the GIF with looping disabled using FFMPEG (with the -loop -1 option)
Hi @larena ,
You can also use the following hack to force the same result if you can not rework the gif image for any reason:
static void img_cb( lv_event_t *e ) {
    lv_gif_t * gif = (lv_gif_t *)e->target;
	lv_timer_del(gif->timer);
void example() {
    LV_IMG_DECLARE(img_bulb_gif);
    lv_obj_t * img;
    img = lv_gif_create(lv_scr_act());
    lv_gif_set_src(img, &img_bulb_gif);
    lv_obj_align(img, LV_ALIGN_LEFT_MID, 20, 0);
    lv_gif_t * gif = (lv_gif_t *)img;
    gif->gif->loop_count = 1;
    lv_obj_add_event_cb( img, img_cb, LV_EVENT_READY, NULL );
Kind Regards,
Pete
Great! I’m thinking about integrating something like this in the main codebase; do you this it would be useful?
Hi @larena ,
I don’t really know if this would be useful to be honest, personally I haven’t used animated GIFs to date. Maybe @kisvegabor or anyone else can comment here… :slight_smile:
Kind Regards,
Pete
animated PNG support would be something worth while… supports 32 bit color smaller file size. better than GIF in almost every way.
Do you know a good C APNG decoder?
I do not. But I can tell you the standard is super easy. It’s a bunch of PNG’s stacked into a single file one right after the other. No reason why you cannot add onto the current PNG decoder. I wrote a decoder for use in Python. I know it won’t do you much good for the code. but I can help out with explaining how it works.
