I have a five key keypad, that is left/right/up/down/ok, and I have several UIs.
In main screen, it is a navigation screen, I use a button matrix to present several choices that I want to provide to the user, Here is the mapping I want to use,
LEFT --> LV_KEY_LEFT
RIGHT --> LV_KEY_RIGHT
UP --> LV_KEY_UP
DOWN --> LV_KEY_DOWN
OK --> LV_KEY_ENTER
The reason that why I do not mapping some of keys to LV_KEY_PREV/NEXT is that in that way, I cannot use up/down key to switch rows between choices, while that is another question
While in another screen, I want to use these keys to navigate between buttons in a same group, the mapping is,
LEFT --> LV_KEY_PREV
RIGHT --> LV_KEY_NEXT
UP --> LV_KEY_PREV
DOWN --> LV_KEY_NEXT
OK --> LV_KEY_ENTER
I tried several choices to achieve this,
Choice 1
Create two drivers(type of lv_indev_drv_t
), register one during system initialization, and switch to another using lv_indev_drv_update()
, while seems it does not work, I tried to search a sample to use this API and failed.
Choice 2
Directly change the driver( lv_indev_drv_t
)'s callback function , read_cb
, and failed too.
Choice 3
Register two input devices for the same keypad, and bind to the group when they are displayed. In some scenario, it works well, while I cannot work out below issue,
In screen A, “OK” key is used to switch to screen B to display a list with several choices to select, in screen B, “OK” key is used to confirm the choice, and back to screen A.
The reality is that after I pressed the OK key in screen A, it sticks to the same screen. After I adding some debug code, I found that it actually switched to screen B, and back to A very quick.
What might the solution or workaround?
stm32f412
v7.7.2
As said in above.
As I said above.
