On the chart, I am attempting to put labels for the X and Y axis without success. I read that we are supposed to use lv_chart_set_margin. I tried 3 different versions of LVGL and they don’t have that function.
3 different environments:
- codeblocks simulator
- micropython environment from lv_chart web page
- Atmel ARM32, arm-none-eabi-gcc.exe
- codeblocks simulator has 7.4-dev
- I don’t know where to find the LVGL version on the live micropython
- On atmel project, I am using v7.7.2
I like to add labels for the chart vertical and horizontal divisions. Only little ticks appear without text.
lv_chart_set_margin does not compile. I tried searching the whole library with a text editor and it does not appear anywhere.
In codeblocks simulator with 7.4-dev:
in lv_conf.h :
#define LV_USE_CHART 1
void lv_ex_chart_web(void)
/*Create a chart*/
lv_obj_t * chart;
chart = lv_chart_create(lv_scr_act(), NULL);
lv_obj_set_size(chart, 200, 150);
lv_obj_align(chart, NULL, LV_ALIGN_CENTER, 0, 0);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE); /*Show lines and points too*/
/*Add two data series*/
lv_chart_series_t * ser1 = lv_chart_add_series(chart, LV_COLOR_RED);
lv_chart_series_t * ser2 = lv_chart_add_series(chart, LV_COLOR_GREEN);
/*Set the next points on 'ser1'*/
lv_chart_set_next(chart, ser1, 10);
lv_chart_set_next(chart, ser1, 30);
lv_chart_set_next(chart, ser1, 70);
lv_chart_set_next(chart, ser1, 90);
/*Directly set points on 'ser2'*/
ser2->points[0] = 90;
ser2->points[1] = 70;
ser2->points[2] = 65;
ser2->points[3] = 65;
ser2->points[4] = 65;
ser2->points[5] = 65;
ser2->points[6] = 65;
ser2->points[7] = 65;
ser2->points[8] = 65;
ser2->points[9] = 65;
/* lv_chart_set_margin(chart, 40);*/
lv_chart_set_x_tick_texts(chart, "1\n2\n3\n4\n5\n6\n7\n8\n9\n", 0, LV_CHART_AXIS_DRAW_LAST_TICK);
lv_chart_set_x_tick_length(chart, 5, 8);
lv_chart_set_y_tick_texts(chart, "123\n456\n789\n5a\n", 2, LV_CHART_AXIS_DRAW_LAST_TICK | LV_CHART_AXIS_INVERSE_LABELS_ORDER);
lv_chart_set_y_tick_length(chart, 5, 8);
lv_chart_refresh(chart); /*Required after direct set*/
In micropython web environment that is available from chart web page:
chart.set_margin(40)
won’t compile
