OLED is noisy (SH1106 128x64 1.3" I2C OLED)
I want to display some text on my 1.3" I2C OLED screen (SH1106) using Zephyr RTOS on NXP’s FRDM-MCXN236.
I have tried the basic text display example
prj.conf
# System and Logging (Turned up to DEBUG level)
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
# Massive Memory to prevent early-boot Stack Overflows
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=32768
# I2C and Display Driver
CONFIG_I2C=y
CONFIG_DISPLAY=y
CONFIG_SSD1306=y
CONFIG_CHARACTER_FRAMEBUFFER=n
# LVGL Subsystem
CONFIG_LVGL=y
# The Monochrome Magic Math
CONFIG_LV_COLOR_DEPTH_1=y
CONFIG_LV_Z_BITS_PER_PIXEL=1
CONFIG_LV_Z_MEM_POOL_SIZE=16384
main.c
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/display.h>
#include <zephyr/logging/log.h>
#include <lvgl.h>
LOG_MODULE_REGISTER(lvgl_debug, LOG_LEVEL_DBG);
int main(void)
    LOG_INF("Starting LVGL Init...");
    const struct device *display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display));
    if (!device_is_ready(display_dev)) {
        LOG_ERR("HARDWARE FAULT: Display not ready! (Did you unplug the USB cable?)");
        return -1;
    display_blanking_off(display_dev);
    /* Safely check if LVGL successfully created a display buffer in the background */
    if (lv_disp_get_default() == NULL) {
        LOG_ERR("SOFTWARE FAULT: LVGL initialized, but failed to bind to the OLED.");
        return -1;
    /* Grab the screen safely */
    lv_obj_t *scr = lv_scr_act();
    /* Force high-contrast colors for monochrome */
    lv_obj_set_style_bg_color(scr, lv_color_black(), LV_PART_MAIN);
    lv_obj_set_style_text_color(scr, lv_color_white(), LV_PART_MAIN);
    lv_obj_t *label1 = lv_label_create(scr);
    lv_label_set_text(label1, "LVGL SUCCESS!");
    lv_obj_align(label1, LV_ALIGN_CENTER, 0, -10);
    lv_obj_t *label2 = lv_label_create(scr);
    lv_label_set_text(label2, "OLED Running");
    lv_obj_align(label2, LV_ALIGN_CENTER, 0, 10);
    while (1) {
        lv_task_handler();
        k_msleep(10);
    return 0;
  • MCU/MPU/Board: FRDM-MCXN236
  • LVGL version: v9.5.0
Hi @vaishnavs,
I found a great blog post about Zephyr + Display. Maybe this tutorial can help you.
Hey @halyssonJr ,
Thank you so much. I’ll try it out andst you know how it goes.
Hey @halyssonJr ,
Thank you so much. It worked
Great, enjoy :slight_smile:
