I need to fix an old project written on version 6.0. Where can I find the documentation for this version. Thank you in advance.
You can find them here.
Thank you !!!
As a heads up, note that those docs are for 6.1, so if you are using 6.0, there will probably be a few APIs mentioned which don’t exist in your version, but it should be good enough for your purposes (and please upgrade if you can!).
My version is 6.11, I found where it was written. The documents helped me a lot. Thank you very much!
