Dear all,
I am trying to port LVGL library to Nordic’s nRF52840-DK for Adafruit’s 2.4" Featherwing display. I have already seen some posts in this forum, but none of them solved my problem. I have followed the LVGL’s official porting guide and I have implemented a driver for the touchscreen’s ILI9341 controller based on the lv_drivers. However, even though the firmware is compiled successfully and the library’s lv_task_handler() and lv_tick_inc() are running, the screen stays blank at all times. To clarify, the lv_task_handler() runs in the mainloop context every 5 ms, while the lv_tick_inc(1) runs inside a high priority timer handler every 1 ms.
To verify that the library runs as expected, I have assigned the nRF52840 on-board buttons to the library as an indev device with a graphical button (lv_ex_get_started_1()) and they seem to respond as expected. I suspect that the problem is located in the ILI9341 drivers.
I am using Nordic’s nRF52840-DK with Adafruit’s 2.4" Featherwing display. I am developing my application with the Segger Embedded Studio.
I am using LVGL release/v7 branch
Port the LVGL library to the nRF52840 DK.
I have tried to modify the lv_drivers for the ILI9341 controller. I have also tried the available esp32 ILI9341 drivers without any success, too. Moreover, I have used Nordic’s default drivers (with modications) and the screen remains blank.
Note that the gfx example available with the nRF SDK is running as expected, so the display and the SPI connections are checked and seem to work fine.
main() function
void main(void)
// Initialize Error Variable
ret_code_t ErrorCode = NRF_SUCCESS;
// Initialize Low-Frequency Clock
ClockInit();
// Initialize Application Timer (For Buttons)
ErrorCode = app_timer_init();
APP_ERROR_CHECK(ErrorCode);
// Initialize Buttons & LEDs
ErrorCode = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, BspEventHandler);
// Initialize Terminal Log
LogInit();
lv_disp_init();
lv_indev_init();
// Initialize LVGL's Timer module
TimerInit();
lv_ex_get_started_1();
while(1)
nrf_delay_ms(5);
lv_task_handler();
lv_disp_init() function
void lv_disp_init(void)
ili9341_init();
static lv_color_t buf_1[LV_HOR_RES_MAX * 10]; /*A buffer for 10 rows*/
lv_disp_buf_init(&disp_buf, buf_1, NULL, LV_HOR_RES_MAX * 10); /*Initialize the display buffer*/
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = ILI9341_WIDTH;
disp_drv.ver_res = ILI9341_HEIGHT;
disp_drv.flush_cb = ili9341_flush;
/*Set a display buffer*/
disp_drv.buffer = &disp_buf;
ili9341_flush() function
void ili9341_flush(lv_disp_drv_t * drv, const lv_area_t * area, const lv_color_t * color_p)
if(area->x2 < 0 || area->y2 < 0 || area->x1 > (ILI9341_WIDTH - 1) || area->y1 > (ILI9341_HEIGHT - 1)) {
lv_disp_flush_ready(drv);
return;
/* Truncate the area to the screen */
int32_t act_x2 = area->x2 > ILI9341_WIDTH - 1 ? ILI9341_WIDTH - 1 : area->x2;
int32_t act_y2 = area->y2 > ILI9341_HEIGHT - 1 ? ILI9341_HEIGHT - 1 : area->y2;
int32_t y;
uint8_t data[4];
int32_t len = len = (act_x2 - act_x1 + 1) * 2;
lv_coord_t w = (area->x2 - area->x1) + 1;
/* window horizontal */
ili9341_write(ILI9341_CMD_MODE, ILI9341_CASET);
data[0] = (uint8_t)(act_x1 >> 8);
data[1] = (uint8_t)act_x1;
data[2] = (uint8_t)(act_x2 >> 8);
data[3] = (uint8_t)act_x2;
ili9341_write_array(ILI9341_DATA_MODE, data, 4);
/* window vertical */
ili9341_write(ILI9341_CMD_MODE, ILI9341_PASET);
data[0] = (uint8_t)(act_y1 >> 8);
data[1] = (uint8_t)act_y1;
data[2] = (uint8_t)(act_y2 >> 8);
data[3] = (uint8_t)act_y2;
ili9341_write(ILI9341_CMD_MODE, ILI9341_RAMWR);
for(y = act_y1; y <= act_y2; y++) {
ili9341_write_array(ILI9341_DATA_MODE, (uint8_t *)color_p, len);
color_p += w;
ili9341_init() function
void ili9341_init(void)
volatile uint8_t data[15];
hardware_init();
/* software reset */
ili9341_write(ILI9341_CMD_MODE, ILI9341_SWRESET);
nrf_delay_ms(120UL);
ili9341_write(ILI9341_CMD_MODE, ILI9341_DISPOFF);
/* startup sequence */
ili9341_write(ILI9341_CMD_MODE, ILI9341_PWCTRLB);
data[0] = 0x00U;
data[1] = 0x83U;
data[2] = 0x30U;
ili9341_write_array(ILI9341_DATA_MODE, data, 3);
ili9341_write(ILI9341_CMD_MODE, ILI9341_PWSEQCTRL);
data[0] = 0x64U;
data[1] = 0x03U;
data[2] = 0x12U;
data[3] = 0x81U;
ili9341_write(ILI9341_CMD_MODE, ILI9341_TIMECTRLA_INT);
data[0] = 0x85U;
data[1] = 0x01U;
data[2] = 0x79U;
ili9341_write(ILI9341_CMD_MODE, ILI9341_PWCTRLA);
data[0] = 0x39U;
data[1] = 0x2cU;
data[2] = 0x00U;
data[3] = 0x34U;
data[4] = 0x02U;
ili9341_write_array(ILI9341_DATA_MODE, data, 5);
ili9341_write(ILI9341_CMD_MODE, ILI9341_PUMPRATIO);
ili9341_write(ILI9341_DATA_MODE, 0x20);
ili9341_write(ILI9341_CMD_MODE, ILI9341_TIMECTRLB);
data[0] = 0x00U;
data[1] = 0x00U;
ili9341_write_array(ILI9341_DATA_MODE, data, 2);
/* power control */
ili9341_write(ILI9341_CMD_MODE, ILI9341_PWCTRL1);
ili9341_write(ILI9341_DATA_MODE, 0x26);
ili9341_write(ILI9341_CMD_MODE, ILI9341_PWCTRL2);
ili9341_write(ILI9341_DATA_MODE, 0x11);
/* VCOM */
ili9341_write(ILI9341_CMD_MODE, ILI9341_VMCTRL1);
data[0] = 0x35U;
data[1] = 0x3eU;
ili9341_write_array(ILI9341_DATA_MODE, data, 2U);
ili9341_write(ILI9341_CMD_MODE, ILI9341_VMCTRL2);
ili9341_write(ILI9341_DATA_MODE, 0xbeU);
/* set orientation */
ili9341_rotate(0U, ILI9341_BGR);
/* 16 bit pixel */
ili9341_write(ILI9341_CMD_MODE, ILI9341_PIXSET);
ili9341_write(ILI9341_DATA_MODE, 0x55U);
/* frame rate */
ili9341_write(ILI9341_CMD_MODE, ILI9341_FRMCTR1);
data[0] = 0x00U;
data[1] = 0x1bU;
#if ILI9341_GAMMA
/* gamma curve set */
ili9341_write(ILI9341_CMD_MODE, ILI9341_GAMSET);
ili9341_write(ILI9341_DATA_MODE, 0x01U);
/* positive gamma correction */
ili9341_write(ILI9341_CMD_MODE, ILI9341_PGAMCTRL);
data[0] = 0x1fU;
data[1] = 0x1aU;
data[2] = 0x18U;
data[3] = 0x0aU;
data[4] = 0x0fU;
data[5] = 0x06U;
data[6] = 0x45U;
data[7] = 0x87U;
data[8] = 0x32U;
data[9] = 0x0aU;
data[10] = 0x07U;
data[11] = 0x02U;
data[12] = 0x07U;
data[13] = 0x05U;
data[14] = 0x00U;
ili9341_write_array(ILI9341_DATA_MODE, data, 15U);
/* negative gamma correction */
ili9341_write(ILI9341_CMD_MODE, ILI9341_NGAMCTRL);
data[0] = 0x00U;
data[1] = 0x25U;
data[2] = 0x27U;
data[3] = 0x05U;
data[4] = 0x10U;
data[5] = 0x09U;
data[6] = 0x3aU;
data[7] = 0x78U;
data[8] = 0x4dU;
data[9] = 0x05U;
data[10] = 0x18U;
data[11] = 0x0dU;
data[12] = 0x38U;
data[13] = 0x3aU;
data[14] = 0x1fU;
data[0] = 0U;
data[1] = 0U;
data[2] = (ILI9341_WIDTH - 1U) >> 8U;
data[3] = (ILI9341_WIDTH - 1U);
ili9341_write_array(ILI9341_DATA_MODE, data, 4U);
data[0] = 0U;
data[1] = 0U;
data[2] = (ILI9341_HEIGHT - 1U) >> 8U;
data[3] = (ILI9341_HEIGHT - 1U);
#if ILI9341_TEARING
/* tearing effect off */
ili9341_write(ILI9341_CMD_MODE, ILI9341_TEOFF);
/* tearing effect on */
ili9341_write(ILI9341_CMD_MODE, ILI9341_TEON);
/* entry mode set */
ili9341_write(ILI9341_CMD_MODE, ILI9341_ETMOD);
ili9341_write(ILI9341_DATA_MODE, 0x07U);
/* display function control */
ili9341_write(ILI9341_CMD_MODE, ILI9341_DISCTRL);
data[0] = 0x0aU;
data[1] = 0x82U;
data[2] = 0x27U;
data[3] = 0x00U;
/* exit sleep mode */
ili9341_write(ILI9341_CMD_MODE, ILI9341_SLPOUT);
nrf_delay_ms(100U);
/* display on */
ili9341_write(ILI9341_CMD_MODE, ILI9341_DISPON);
nrf_delay_ms(20U);
ili9341_write() and ili9341_write_array() functions
static inline void ili9341_write(uint8_t Mode, uint8_t Data)
// Write Command
if(Mode == ILI9341_CMD_MODE)
nrf_gpio_pin_clear(ILI9341_DC_PIN);
// Write Data
else if(Mode == ILI9341_DATA_MODE)
nrf_gpio_pin_set(ILI9341_DC_PIN);
nrf_gpio_pin_clear(ILI9341_SS_PIN);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, Data, 1U, NULL, 0));
nrf_gpio_pin_set(ILI9341_SS_PIN);
static inline void ili9341_write_array(uint8_t Mode, uint8_t *Data, uint16_t Len)
// Write Command
// Write Data
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, Data, Len, NULL, 0));
} // End Of ili9341_write_array()
I am really sorry for the long post, but I cannot figure it out. It may be something simple that I am not seeing right now.
Thank you in advance for your help,
Aris
