We are using LVGL for GUI and we figured that when we set the refreshing rate above 2FPS, the device will freeze while writing the data into internal flash memory on nrf52832. The system works perfectly fine when refreshing rate below1FPS. We use the app_timer() provided in nrf libaray as a way to refresh.
Is there any certain restriction could not be found in documentation?
NRF52832
v8.3.3
Figured what freeze the device, we doubt it might be cache size issue? We set LV_MEM_SIZE as 10k tho.
Tried different FPS, below1 FPS works fine, above 2FPS will freeze.
