I want to detect swipe gestures (left, right, up, down) on my CST816S touch display. My ultimate goal is to use these gestures to navigate between different screens.
I have followed the instructions from this doc.
My touch driver for the CST816S is working. I can successfully detect both LV_EVENT_PRESSED and LV_EVENT_PRESSING and can read the correct x,y coordinates. However, gestures are not being detected.
Not mentioned in docs but have also enabled LV_USE_GESTURE_RECOGNITION also in lv_conf.h
// main.cpp
#include <Arduino.h>
#include "app/app.h"
#include <lvgl.h>
#include "hal/display/display_setup.h"
#include "hal/display/touch_setup.h"
#include "hal/display/lvgl_setup.h"
#include "app/ui/home/home_fragment.h"
App myApp;
void home()
lv_obj_t *root = lv_obj_create(lv_screen_active());
lv_obj_set_size(root, 240, 240);
auto *manager = lv_fragment_manager_create(NULL);
lv_fragment_t *fragment = lv_fragment_create(HomeFragment::getLvFragment(), NULL);
lv_fragment_manager_push(manager, fragment, &root);
static void debug_touch_cb(lv_event_t *e)
lv_point_t p;
lv_indev_get_point(lv_event_get_indev(e), &p);
Serial.printf("Touch: x=%d y=%d\n", p.x, p.y);
static void gesture_event_cb(lv_event_t *e)
lv_dir_t dir = lv_indev_get_gesture_dir(lv_indev_active());
switch (dir)
case LV_DIR_LEFT:
Serial.println("Gesture: Swipe Left");
break;
case LV_DIR_RIGHT:
Serial.println("Gesture: Swipe Right");
break;
case LV_DIR_TOP:
Serial.println("Gesture: Swipe Up");
break;
case LV_DIR_BOTTOM:
Serial.println("Gesture: Swipe Down");
break;
default:
Serial.println("Gesture: None");
break;
void create_touch_test_screen()
lv_obj_t *root = lv_obj_create(lv_scr_act());
lv_obj_center(root);
lv_obj_remove_flag(root, LV_OBJ_FLAG_SCROLLABLE);
lv_obj_set_scroll_dir(root, LV_DIR_NONE);
lv_obj_set_scrollbar_mode(root, LV_SCROLLBAR_MODE_OFF);
lv_obj_add_event_cb(root, gesture_event_cb, LV_EVENT_GESTURE, NULL);
lv_obj_add_event_cb(root, debug_touch_cb, LV_EVENT_PRESSED, NULL);
lv_obj_add_event_cb(root, debug_touch_cb, LV_EVENT_PRESSING, NULL);
void setup()
Serial.begin(115200);
displaySetup();
touchSetup();
lvglSetup();
// home();
create_touch_test_screen();
void loop()
lv_timer_handler();
delay(10);
// Callback function(lv_indev_set_read_cb)
void touchCallback(lv_indev_t *indev, lv_indev_data_t *data)
if (touchpad.available())
uint16_t x = touchpad.x;
uint16_t y = touchpad.y;
data->point.x = x;
data->point.y = y;
- MCU/MPU/Board: ESP32 Dev Board
- LVGL version: 9.3.0
