Noise on OLED (SSD1306)
I am trying to use LittlevGL on OLED(SSD1306) using Nordic’s nRF52840.
I am not getting the desired output. It is noise which seems random but is the same every time you power on the OLED.
MCU - nRF52840
What do you experience?
Screen is showing random noise. Actually the pattern made by this noise is always same.
I am guessing there is some problem with the generated buffer.
I have ported LittlevGL using guide and set callbacks for disp_flush, set_px_cb, rounder_cb. Using these guides.
https://blog.littlevgl.com/2019-05-06/oled
https://docs.littlevgl.com/en/html/porting/index.html
What do you expect?
Any idea how can I debug ? Or is there some problem with my code.
main.c
    lv_port_disp_init();
    lv_obj_t * scr = lv_disp_get_scr_act(NULL);
    lv_theme_t * th = lv_theme_mono_init(0, NULL);
    /* Set the mono system theme */
    lv_theme_set_current(th);
    /*Create a Label on the currently active screen*/
    lv_obj_t *label1;
    label1 =  lv_label_create(scr, NULL);
    lv_label_set_text(label1, "Hello World");
    lv_obj_set_pos(label1,30, 30);// position, position);
    NRF_LOG_INFO("Towards end of main"); NRF_LOG_FLUSH();
    while (1) {
        lv_task_handler();
        lv_tick_inc(1);
        nrf_delay_ms(1);
disp_flush function
        /*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
        int16_t x;
        int16_t y;
        uint8_t *buf = (uint8_t*) color_p;
                /* Put a pixel to the display. For example: */
                /* put_px(x, y, *color_p)*/
                Adafruit_GFX_drawPixel(x, y, *buf);
                buf++;
        NRF_LOG_INFO("Written to screen"); NRF_LOG_FLUSH();
        /* IMPORTANT!!!
A screenshot would be useful.
I was debugging further and saw this.
I tried this code without lvgl library and this is the output.
My Callback function
    int16_t x;
    int16_t y;
    //copyToBuffer(buf);
    NRF_LOG_INFO("X1 Value %d | X2 Value %d | Y1 Value %d | Y2 Value %d", area->x1, area->x2, area->y1, area->y2); NRF_LOG_FLUSH();
            SSD1306_drawPixel(x, y, *buf);
            buf++;
    SSD1306_display();
    /* IMPORTANT!!!
This means that something is wrong with your display driver, not LittlevGL.
What color depth are you using? You should use lv_color_toX(*color_p) (where X is the display’s color depth) instead of casting color_p to a uint8_t directly.
For example, if you want a 16-bit RGB color value, you should call lv_color_to16 and use the value it returns instead of casting lv_color_t * to uint16_t *.
I am using 1 as colour depth.
The function SSD1306_drawPixel() correctly draws pixel at given coordinates. What could be wrong with my display driver ?
Your disp_flush function is not handling the colors from LittlevGL correctly.
Here’s an example for another display controller that uses the lv_color_to1 function, rather than casting (which is not portable):
UPDATE [SOLVED]
I was using a callback function set_px_cb which was taken from this blog.
uint16_t byte_index = x + (( y>>3 ) * buf_w);
  uint8_t  bit_index  = y & 0x7;
  // == 0 inverts, so we get blue on black
  if ( color.full == 0 ) {
    BIT_SET( buf[ byte_index ] , bit_index );
  else {
    BIT_CLEAR( buf[ byte_index ] , bit_index );
Removing this function and printing each pixel from buffer using this callback function solved my problem.
    int16_t x;
    int16_t y;
            SSD1306_drawPixel(x, y, lv_color_to1(*color_p));
            color_p++;
    SSD1306_display();
    /* IMPORTANT!!!
How to invert buffer ?
I think one of the uses of this function was there to invert pixels. If this function is interfering with printing of pixels then how can I correct this function to invert my display ?
XORing the color with 1 should work: lv_color_to1(*color_p) ^ 1
1 XOR 1 = 0
0 XOR 1 = 1
Thank You. That works very well.
Another problem I am facing is that content is being displayed in segments.
3a9iyl
I analysed the function calls and found that the disp_flush function is called around 8 times with different area segments segments.
For eg the first call to disp_flush is with area segments X1 = 0, X2=64 and Y1=0, Y2=8
the second call to disp_flush is with area segments X1 = 0, X2=64 and Y1=8, Y2=16
and so on…
**How can I increase speed of display process ? **
You can increase your display buffer size. That will reduce the number of calls to disp_flush.
To increase the speed further you’ll have to optimize the loop. For example, on other SSD display controllers, you can avoid setting the X and Y window before every pixel and just set it once. That has proved to be a huge speedup in my experience.
