I am using STM32L4R9I Discovery. The compiler is gcc
I want to have a normal button like this link:
https://camo.githubusercontent.com/31704de54ed46c4906599cfb1bc196f73196a2e7/68747470733a2f2f646f63732e6c6974746c6576676c2e636f6d2f656e2f6d6973632f73696d706c655f627574746f6e5f6578616d706c652e676966
I performed tasks in this website:
https://docs.littlevgl.com/en/html/porting/project.html
I also wrote the driver for the MB1314 (display module).
I based on the STM32L4R9I_discovery library and DSI library to write the driver:
the link is:
- BSP: https://github.com/STMicroelectronics/STM32CubeL4/tree/d00623f229d09f3a1be050bdb0606b8870fa5d1c/Projects/32L4R9IDISCOVERY/Examples/BSP
- DSI:
https://github.com/STMicroelectronics/STM32CubeL4/tree/d00623f229d09f3a1be050bdb0606b8870fa5d1c/Projects/32L4R9IDISCOVERY/Examples/DSI
the driver of display module:
#include "lv_conf.h"
#include "display.h"
#include "lvgl/src/lv_hal/lv_hal.h"
#include "stm32l4xx_hal.h"
#include "stm32l4xx_hal_ltdc.h"
#include "stm32l4xx_hal_dma2d.h"
#include "stm32l4xx_hal_dsi.h"
#include "stm32l4xx_hal_rcc.h"
#include "stm32l4r9i_discovery.h"
#include "stm32l4r9i_discovery_lcd.h"
#include "stm32l4r9i_discovery_psram.h"
#include "st7735/st7735.h"
#define LAYER0_ADDRESS GFXMMU_VIRTUAL_BUFFER0_BASE
//**************STATIC PROTOTYPES**************
/* For LittlevGL */
static void tft_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area,
lv_color_t *color_p);
/* LCD */
/* RAM */
static void CopyBuffer(const uint32_t *pSrc, uint32_t *pDst, uint16_t x, uint16_t y, uint16_t xsize, uint16_t ysize);
// ************STATIC VARIABLES***************
extern LTDC_HandleTypeDef hltdc_discovery;
//static DMA2D_HandleTypeDef hdma2d;
extern DSI_HandleTypeDef hdsi_discovery;
DSI_VidCfgTypeDef hdsivideo_handle;
DSI_PLLInitTypeDef dsiPllInit;
//static RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
static uint32_t *my_fb = (uint32_t*)LAYER0_ADDRESS;
static DMA2D_HandleTypeDef Dma2dHandle;
// ************ GLOBAL FUNCTION *************
// ********* initialize the display ***********
void tft_init(void) {
BSP_PSRAM_Init();
BSP_LCD_Init();
BSP_LCD_SelectLayer(0);
HAL_DSI_ShortWrite(&(hdsi_discovery), 0, DSI_DCS_SHORT_PKT_WRITE_P0,
DSI_SET_DISPLAY_ON, 0x00);
BSP_LCD_Refresh();
static lv_color_t buf[TFT_HOR_RES * 10];
lv_disp_buf_init(&disp_buf, buf, NULL, TFT_HOR_RES * 10);
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = tft_flush_cb;
disp_drv.buffer = &disp_buf;
lv_color_t *color_p) {
CopyBuffer((const uint32_t*) color_p, my_fb, area->x1, area->y1,
lv_area_get_width(area), lv_area_get_height(area));
HAL_DSI_Refresh(&hdsi_discovery);
lv_disp_flush_ready(drv);
/*lv_disp_t * disp;
int32_t x,y;
for (y = area->y1; y<= area->y2; y++)
for (x = area->x1; y <= area->x2; x++)
put_px(x, y, *color_p);
color_p++;
lv_disp_flush_ready(disp);*/
uint32_t destination = (uint32_t)pDst + (y * 390 + x) * 4;
uint32_t source = (uint32_t)pSrc;
Dma2dHandle.Instance = DMA2D;
/*##-1- Configure the DMA2D Mode, Color Mode and output offset #############*/
Dma2dHandle.Init.Mode = DMA2D_M2M_PFC;
Dma2dHandle.Init.ColorMode = DMA2D_OUTPUT_RGB888;
Dma2dHandle.Init.OutputOffset = 1024 - 390;
Dma2dHandle.Init.AlphaInverted = DMA2D_REGULAR_ALPHA; /* No Output Alpha Inversion */
Dma2dHandle.Init.RedBlueSwap = DMA2D_RB_REGULAR; /* No Output Red & Blue swap */
Dma2dHandle.Init.BytesSwap = DMA2D_BYTES_REGULAR; /* Regular output byte order */
Dma2dHandle.Init.LineOffsetMode = DMA2D_LOM_PIXELS; /* Pixel mode */
/*##-2- Foreground Configuration ###########################################*/
Dma2dHandle.LayerCfg[1].InputColorMode = DMA2D_INPUT_RGB888;
Dma2dHandle.LayerCfg[1].InputOffset = 0;
Dma2dHandle.LayerCfg[1].AlphaMode = DMA2D_NO_MODIF_ALPHA;
Dma2dHandle.LayerCfg[1].InputAlpha = 0xFF; /* Not used */
Dma2dHandle.LayerCfg[1].RedBlueSwap = DMA2D_RB_SWAP; //DMA2D_RB_REGULAR; /* No ForeGround Red/Blue swap */
Dma2dHandle.LayerCfg[1].AlphaInverted = DMA2D_REGULAR_ALPHA; /* No ForeGround Alpha inversion */
/* DMA2D Initialization */
if(HAL_DMA2D_Init(&Dma2dHandle) == HAL_OK)
if(HAL_DMA2D_ConfigLayer(&Dma2dHandle, 1) == HAL_OK)
if (HAL_DMA2D_Start(&Dma2dHandle, source, destination, xsize, ysize) == HAL_OK)
/* Polling For DMA transfer */
HAL_DMA2D_PollForTransfer(&Dma2dHandle, 100);
the code of button i wrote to test:
* theButton.c
* Created on: Jan 3, 2020
* Author: laptop88
#include "theButton.h"
//#if LV_USE_BTN && LV_USE_TESTS
//void btn_event_cb(lv_obj_t *btn, lv_event_t);
void lv_button(void)
lv_obj_t * btn = lv_btn_create(lv_disp_get_scr_act(NULL), NULL);
lv_obj_set_pos(btn, 10, 10);
lv_obj_set_size(btn, 10, 10);
lv_obj_t * label = lv_label_create(btn, NULL);
lv_label_set_text(label, "button");
static lv_style_t style_rel;
lv_style_copy(&style_rel, &lv_style_pretty);
style_rel.body.main_color = LV_COLOR_ORANGE;
void btn_event_cb(lv_obj_t * btn, lv_event_t event)
if (event == LV_EVENT_CLICKED)
printf("clicked");
//#endif
So I want to ask what might cause the current situation.
