I am attempting to get lvgl working on my NodeMCU-32s (ESP32 wroom) clone, and so far I can initialize the 7" display (using the RA8875 controller and code (from Adafruit) with a label. That part works fine.
The problem occurs when I go to update the label to change the text (e.g., using a task every 500 ms). the original text remains in place on the screen, however any subsequent text updates cause ghosted lines to be drawn around the original text. I even enabled the FPS counter in the bottom corner, and it does the same thing across the bottom.
CLion + PlatformIO
7.9
To be able to update the UI, and it be reflected correctly on screen.
I’ve tried enabling double-buffering to no avail.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_RA8875.h>
#include <lvgl.h>
#define RA8875_INT 13
#define RA8875_CS 5
#define RA8875_RESET 12
#define BUFFER_SIZE (LV_HOR_RES_MAX * 10)
#define NBR_PIXELS_IN_BUFFER (BUFFER_SIZE)
Adafruit_RA8875 get_tft() {
static Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
return tft;
static lv_color_t buf0[BUFFER_SIZE], buf1[BUFFER_SIZE];
void display_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p);
void task(lv_task_t * task) {
static uint8_t toggle = 0;
auto * label = (lv_obj_t *) task->user_data;
if ((toggle++ % 2) != 0) {
lv_label_set_text(label, "Hello Arduino! (V7.9.X)");
} else {
lv_label_set_text(label, "Hello World!");
void setup() {
Serial.begin(115200);
Adafruit_RA8875 tft = get_tft();
tft.begin(RA8875_800x480);
tft.setRotation(1);
tft.displayOn(true);
tft.GPIOX(true);
tft.touchEnable(true);
tft.fillScreen(RA8875_WHITE);
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024);
tft.PWM1out(255);
pinMode(RA8875_INT, INPUT);
digitalWrite(RA8875_INT, HIGH);
lv_disp_buf_init(&disp_buf, buf0, buf1, NBR_PIXELS_IN_BUFFER);
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.flush_cb = display_flush;
disp_drv.buffer = &disp_buf;
lv_obj_t * label = lv_label_create(lv_scr_act(), nullptr);
lv_label_set_text(label, "Hello Arduino! (V7.9.x)");
lv_obj_align(label, nullptr, LV_ALIGN_CENTER, 0, 0);
lv_task_create(task, 500, LV_TASK_PRIO_MID, label);
void loop() {
lv_task_handler();
delay(5);
void display_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p) {
tft.startWrite();
tft.drawPixels(&color_p->full, (w * h), area->x1, area->y1);
tft.endWrite();
lv_disp_flush_ready(disp);
https://imgur.com/a/obT7biC - video showing problem
