Hi everybody,
I recently changed the model of my display, going from SC32-01 to SC01plus… more memory and not the same display.
going through several tests with multiples drivers and platforms, I always have the same problem.
after reinstalling the driver, I always have a compilation error :
“fatal error: …/…/lv_conf.h: No such file or directory
#include “…/…/lv_conf.h” /Else assume lv_conf.h is next to the lvgl folder/”
I normally solve this problem by modifying the line 41 of “LV_CONF_INCLUDE_SIMPLE” from
#include "../../lv_conf.h"
//to
#include "lv_conf.h"
and it’s working fine but I really don’t like it.
according to this code:
#ifndef LV_CONF_SKIP
#ifdef LV_CONF_PATH /*If there is a path defined for lv_conf.h use it*/
#define __LV_TO_STR_AUX(x) #x
#define __LV_TO_STR(x) __LV_TO_STR_AUX(x)
#include __LV_TO_STR(LV_CONF_PATH)
#undef __LV_TO_STR_AUX
#undef __LV_TO_STR
#elif defined(LV_CONF_INCLUDE_SIMPLE) /*Or simply include lv_conf.h is enabled*/
#else
#include "../../lv_conf.h" /*Else assume lv_conf.h is next to the lvgl folder*/
if LV_CONF_INCLUDE_SIMPLE is defined, that should solve this problem…
I’ve tried to do #define LV_CONF_INCLUDE_SIMPLE at the first line of my code but it doesn’t work…
is someone can help me to do this properly instead of badly modifying a really good library?
Thank you for your help.
