Need help with ili9488+esp32+esp-idf
esp32-wrover-ie
run LVGL with ili9488 using SPI (OS Ubuntu 24.4, VS Code, ESP-IDF)
I’m trying to set up vs code + esp-idf + lvgl to try some simple example with ili9488.
my steps:
  1. Create blank project.
  2. Make folder “components” in root of my project.
  3. go to “components” and “git clone GitHub - lvgl/lvgl: LVGL is a free, full-featured embedded UI library for devices from small MCUs to 3D-capable MPUs, enhanced by LVGL Pro, a professional editor and tooling. · GitHub
  4. go to idf.py menuconfig and see LVGL Configuration menu item
  5. Choose FreeRTOS
  6. Go to device, but no ili9488.
  7. OK. “git clone GitHub - lvgl/lvgl_esp32_drivers: Drivers for ESP32 to be used with LVGL · GitHub” to “components”
  8. idf.py menuconfig. Now i see new menu item LVGL Esp Drivers
  9. Select a display controller model. (ILI9488), set up pins and save config.
  10. Now im try to build blank code (just this):
#include <stdio.h>
void app_main(void)
and got many errors in files “disp_driver.h, disp_spi.h, esp_lcd_backlight.h”:
“error: unknown type name ‘lv_disp_drv_t’; did you mean ‘lv_fs_drv_t’?”
“fatal error: driver/spi_master.h: No such file or directory”
What i doing wrong? Thanks!
Now, im try to figure out my project with idf.py add-dependency…
I found ili9488 driver at Search • ESP Component Registry
my steps:
  1. Create sample project with esp-idf
  2. idf.py add-dependency “lvgl/lvgl^9.2.2”
  3. idf.py add-dependency “atanisoft/esp_lcd_ili9488^1.0.10”
  4. Run SDL Configuration Editor and some foдders was added to my project(managed_components/atanisoft__esp_lcd_ili9488, lvgl__lvgl)
  5. Now my empty project was build without errors.
  6. I tried the example that comes with the driver and got errors: lv_disp_draw_buf_t, lv_disp_drv_t unknown type; ‘CONFIG_TFT_BACKLIGHT_PIN’ undeclared and others
  7. I really don’t understand what else needs to be configured and where. On the page https://components.espressif.com/components/atanisoftesp_lcd_ili9488/versions/1.0.10 I see some pieces of code, but I can’t find where to change it. Please help me figure it out before I completely die.
  8. I found that the problem v_disp_draw_buf_t, lv_disp_drv_t is a very old problem, but it still remains in the latest versions of lgv and the driver? Or is it a problem of outdated examples? Now I’m not sure if my project will work with this library at all. It’s very sad, because it’s a very cool library. And all I need is a working usage example for my screen.
    Example code:
 * SPDX-FileCopyrightText: 2022 atanisoft (github.com/atanisoft)
 * SPDX-License-Identifier: MIT
#include <driver/gpio.h>
#include <driver/ledc.h>
#include <driver/spi_master.h>
#include <esp_err.h>
#include <esp_freertos_hooks.h>
#include <esp_log.h>
#include <esp_lcd_panel_io.h>
#include <esp_lcd_panel_vendor.h>
#include <esp_lcd_panel_ops.h>
#include <esp_lcd_ili9488.h>
#include <esp_timer.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <lvgl.h>
#include <stdio.h>
#include "sdkconfig.h"
// Uncomment the following line to enable using double buffering of LVGL color
// data.
// #define USE_DOUBLE_BUFFERING 1
static const char *TAG = "main";
static const int DISPLAY_HORIZONTAL_PIXELS = 320;
static const int DISPLAY_VERTICAL_PIXELS = 480;
static const int DISPLAY_COMMAND_BITS = 8;
static const int DISPLAY_PARAMETER_BITS = 8;
static const unsigned int DISPLAY_REFRESH_HZ = 40000000;
static const int DISPLAY_SPI_QUEUE_LEN = 10;
static const int SPI_MAX_TRANSFER_SIZE = 32768;
// Default to 25 lines of color data
static const size_t LV_BUFFER_SIZE = DISPLAY_HORIZONTAL_PIXELS * 25;
static const int LVGL_UPDATE_PERIOD_MS = 5;
static const ledc_mode_t BACKLIGHT_LEDC_MODE = LEDC_LOW_SPEED_MODE;
static const ledc_channel_t BACKLIGHT_LEDC_CHANNEL = LEDC_CHANNEL_0;
static const ledc_timer_t BACKLIGHT_LEDC_TIMER = LEDC_TIMER_1;
static const ledc_timer_bit_t BACKLIGHT_LEDC_TIMER_RESOLUTION = LEDC_TIMER_10_BIT;
static const uint32_t BACKLIGHT_LEDC_FRQUENCY = 5000;
static esp_lcd_panel_io_handle_t lcd_io_handle = NULL;
static esp_lcd_panel_handle_t lcd_handle = NULL;
static lv_disp_draw_buf_t lv_disp_buf; //ERROR not found
static lv_disp_drv_t lv_disp_drv;  //ERROR not found
static lv_disp_t *lv_display = NULL;
static lv_color_t *lv_buf_1 = NULL;
static lv_color_t *lv_buf_2 = NULL;
static lv_obj_t *meter = NULL;
static lv_style_t style_screen;
static void update_meter_value(void *indic, int32_t v)
    lv_meter_set_indicator_end_value(meter, indic, v); //ERROR implicit declaration of function
static bool notify_lvgl_flush_ready(esp_lcd_panel_io_handle_t panel_io,
    esp_lcd_panel_io_event_data_t *edata, void *user_ctx)
    lv_disp_drv_t *disp_driver = (lv_disp_drv_t *)user_ctx;
    lv_disp_flush_ready(disp_driver);
    return false;
static void lvgl_flush_cb(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t *color_map)
    esp_lcd_panel_handle_t panel_handle = (esp_lcd_panel_handle_t) drv->user_data;
    int offsetx1 = area->x1;
    int offsetx2 = area->x2;
    int offsety1 = area->y1;
    int offsety2 = area->y2;
    esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, color_map);
static void IRAM_ATTR lvgl_tick_cb(void *param)
	lv_tick_inc(LVGL_UPDATE_PERIOD_MS);
static void display_brightness_init(void)
    const ledc_channel_config_t LCD_backlight_channel =
        .gpio_num = (gpio_num_t)CONFIG_TFT_BACKLIGHT_PIN,
        .speed_mode = BACKLIGHT_LEDC_MODE,
        .channel = BACKLIGHT_LEDC_CHANNEL,
        .intr_type = LEDC_INTR_DISABLE,
        .timer_sel = BACKLIGHT_LEDC_TIMER,
        .duty = 0,
        .hpoint = 0,
        .flags =
            .output_invert = 0
    const ledc_timer_config_t LCD_backlight_timer =
        .duty_resolution = BACKLIGHT_LEDC_TIMER_RESOLUTION,
        .timer_num = BACKLIGHT_LEDC_TIMER,
        .freq_hz = BACKLIGHT_LEDC_FRQUENCY,
        .clk_cfg = LEDC_AUTO_CLK
    ESP_LOGI(TAG, "Initializing LEDC for backlight pin: %d", CONFIG_TFT_BACKLIGHT_PIN);
    ESP_ERROR_CHECK(ledc_timer_config(&LCD_backlight_timer));
    ESP_ERROR_CHECK(ledc_channel_config(&LCD_backlight_channel));
void display_brightness_set(int brightness_percentage)
    if (brightness_percentage > 100)
        brightness_percentage = 100;
    else if (brightness_percentage < 0)
        brightness_percentage = 0;
    ESP_LOGI(TAG, "Setting backlight to %d%%", brightness_percentage);
    // LEDC resolution set to 10bits, thus: 100% = 1023
    uint32_t duty_cycle = (1023 * brightness_percentage) / 100;
    ESP_ERROR_CHECK(ledc_set_duty(BACKLIGHT_LEDC_MODE, BACKLIGHT_LEDC_CHANNEL, duty_cycle));
    ESP_ERROR_CHECK(ledc_update_duty(BACKLIGHT_LEDC_MODE, BACKLIGHT_LEDC_CHANNEL));
void initialize_spi()
    ESP_LOGI(TAG, "Initializing SPI bus (MOSI:%d, MISO:%d, CLK:%d)",
             CONFIG_SPI_MOSI, CONFIG_SPI_MISO, CONFIG_SPI_CLOCK);
    spi_bus_config_t bus =
        .mosi_io_num = CONFIG_SPI_MOSI,
        .miso_io_num = CONFIG_SPI_MISO,
        .sclk_io_num = CONFIG_SPI_CLOCK,
        .quadwp_io_num = GPIO_NUM_NC,
        .quadhd_io_num = GPIO_NUM_NC,
        .data4_io_num = GPIO_NUM_NC,
        .data5_io_num = GPIO_NUM_NC,
        .data6_io_num = GPIO_NUM_NC,
        .data7_io_num = GPIO_NUM_NC,
        .max_transfer_sz = SPI_MAX_TRANSFER_SIZE,
        .flags = SPICOMMON_BUSFLAG_SCLK | SPICOMMON_BUSFLAG_MISO |
                 SPICOMMON_BUSFLAG_MOSI | SPICOMMON_BUSFLAG_MASTER,
        .intr_flags = ESP_INTR_FLAG_LOWMED | ESP_INTR_FLAG_IRAM
    ESP_ERROR_CHECK(spi_bus_initialize(SPI2_HOST, &bus, SPI_DMA_CH_AUTO));
void initialize_display()
    const esp_lcd_panel_io_spi_config_t io_config =
        .cs_gpio_num = CONFIG_TFT_CS_PIN,
        .dc_gpio_num = CONFIG_TFT_DC_PIN,
        .spi_mode = 0,
        .pclk_hz = DISPLAY_REFRESH_HZ,
        .trans_queue_depth = DISPLAY_SPI_QUEUE_LEN,
        .on_color_trans_done = notify_lvgl_flush_ready,
        .user_ctx = &lv_disp_drv,
        .lcd_cmd_bits = DISPLAY_COMMAND_BITS,
        .lcd_param_bits = DISPLAY_PARAMETER_BITS,
        .flags =
#if ESP_IDF_VERSION < ESP_IDF_VERSION_VAL(5, 0, 0)
            .dc_as_cmd_phase = 0,
            .dc_low_on_data = 0,
            .octal_mode = 0,
            .lsb_first = 0
#else
            .octal_mode = 0,
            .sio_mode = 0,
            .lsb_first = 0,
            .cs_high_active = 0
    const esp_lcd_panel_dev_config_t lcd_config =
        .reset_gpio_num = CONFIG_TFT_RESET_PIN,
        .color_space = CONFIG_DISPLAY_COLOR_MODE,
        .bits_per_pixel = 18,
        .flags =
            .reset_active_high = 0
        .vendor_config = NULL
    ESP_ERROR_CHECK(
        esp_lcd_new_panel_io_spi((esp_lcd_spi_bus_handle_t)SPI2_HOST, &io_config, &lcd_io_handle));
    ESP_ERROR_CHECK(esp_lcd_new_panel_ili9488(lcd_io_handle, &lcd_config, LV_BUFFER_SIZE, &lcd_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_reset(lcd_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_init(lcd_handle));
    ESP_ERROR_CHECK(esp_lcd_panel_invert_color(lcd_handle, false));
    ESP_ERROR_CHECK(esp_lcd_panel_swap_xy(lcd_handle, false));
    ESP_ERROR_CHECK(esp_lcd_panel_mirror(lcd_handle, true, false));
    ESP_ERROR_CHECK(esp_lcd_panel_set_gap(lcd_handle, 0, 0));
    ESP_ERROR_CHECK(esp_lcd_panel_disp_off(lcd_handle, false));
#else
    ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(lcd_handle, true));
void initialize_lvgl()
    ESP_LOGI(TAG, "Initializing LVGL");
    ESP_LOGI(TAG, "Allocating %zu bytes for LVGL buffer", LV_BUFFER_SIZE * sizeof(lv_color_t));
    lv_buf_1 = (lv_color_t *)heap_caps_malloc(LV_BUFFER_SIZE * sizeof(lv_color_t), MALLOC_CAP_DMA);
#if USE_DOUBLE_BUFFERING
    ESP_LOGI(TAG, "Allocating %zu bytes for second LVGL buffer", LV_BUFFER_SIZE * sizeof(lv_color_t));
    lv_buf_2 = (lv_color_t *)heap_caps_malloc(LV_BUFFER_SIZE * sizeof(lv_color_t), MALLOC_CAP_DMA);
    ESP_LOGI(TAG, "Creating LVLG display buffer");
    lv_disp_draw_buf_init(&lv_disp_buf, lv_buf_1, lv_buf_2, LV_BUFFER_SIZE);
    ESP_LOGI(TAG, "Initializing %dx%d display", DISPLAY_HORIZONTAL_PIXELS, DISPLAY_VERTICAL_PIXELS);
    lv_disp_drv_init(&lv_disp_drv);
    lv_disp_drv.hor_res = DISPLAY_HORIZONTAL_PIXELS;
    lv_disp_drv.ver_res = DISPLAY_VERTICAL_PIXELS;
    lv_disp_drv.flush_cb = lvgl_flush_cb;
    lv_disp_drv.draw_buf = &lv_disp_buf;
    lv_disp_drv.user_data = lcd_handle;
    lv_display = lv_disp_drv_register(&lv_disp_drv);
    ESP_LOGI(TAG, "Creating LVGL tick timer");
    const esp_timer_create_args_t lvgl_tick_timer_args =
        .callback = &lvgl_tick_cb,
        .name = "lvgl_tick"
    esp_timer_handle_t lvgl_tick_timer = NULL;
    ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
    ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, LVGL_UPDATE_PERIOD_MS * 1000));
void create_demo_ui()
    lv_obj_t *scr = lv_disp_get_scr_act(NULL);
    // Set the background color of the display to black.
    lv_style_init(&style_screen);
    lv_style_set_bg_color(&style_screen, lv_color_black());
    lv_obj_add_style(lv_scr_act(), &style_screen, LV_STATE_DEFAULT);
    // Create a meter which can be animated.
    meter = lv_meter_create(scr);
    lv_obj_center(meter);
    lv_obj_set_size(meter, 200, 200);
    // Add a scale first
    lv_meter_scale_t *scale = lv_meter_add_scale(meter);
    lv_meter_set_scale_ticks(meter, scale, 41, 2, 10, lv_palette_main(LV_PALETTE_GREY));
    lv_meter_set_scale_major_ticks(meter, scale, 8, 4, 15, lv_color_black(), 10);
    lv_meter_indicator_t *indic;
    // Add a blue arc to the start
    indic = lv_meter_add_arc(meter, scale, 3, lv_palette_main(LV_PALETTE_BLUE), 0);
    lv_meter_set_indicator_start_value(meter, indic, 0);
    lv_meter_set_indicator_end_value(meter, indic, 20);
    // Make the tick lines blue at the start of the scale
    indic = lv_meter_add_scale_lines(meter, scale, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_BLUE), false, 0);
    // Add a red arc to the end
    indic = lv_meter_add_arc(meter, scale, 3, lv_palette_main(LV_PALETTE_RED), 0);
    lv_meter_set_indicator_start_value(meter, indic, 80);
    lv_meter_set_indicator_end_value(meter, indic, 100);
    // Make the tick lines red at the end of the scale
    indic = lv_meter_add_scale_lines(meter, scale, lv_palette_main(LV_PALETTE_RED), lv_palette_main(LV_PALETTE_RED), false, 0);
    // Add a needle line indicator
    indic = lv_meter_add_needle_line(meter, scale, 4, lv_palette_main(LV_PALETTE_GREY), -10);
    // Create an animation to set the value
    lv_anim_t a;
    lv_anim_init(&a);
    lv_anim_set_exec_cb(&a, update_meter_value);
    lv_anim_set_var(&a, indic);
    lv_anim_set_values(&a, 0, 100);
    lv_anim_set_time(&a, 2000);
    lv_anim_set_repeat_delay(&a, 100);
    lv_anim_set_playback_time(&a, 500);
    lv_anim_set_playback_delay(&a, 100);
    lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
    lv_anim_start(&a);
void app_main()
    display_brightness_init();
    display_brightness_set(0);
    initialize_spi();
    initialize_display();
    initialize_lvgl();
    create_demo_ui();
    display_brightness_set(75);
    while (1)
        lv_timer_handler();
Library developers, give at least some kind of sign! Our only hope is for you!
Hi @unregistered33
Can you find I found I found ili9488 driver at Search • ESP Component Registry still? It looks dispear!!
