I am new to your forum and hopefully I format all this properly. I am trying to understand the build environment for LVGL. I am trying to write an application that will run on a Raspberry Pi 5 on the X desktop. After a few days of playing around I did manage to get the demo/example program to run. I believe it was the ivgl_sim program.
Being an old school system programmer I am more used to the install libraries and link. Is that a possible way to work with LVGL? Or do I need to have the source tree for LVGL and SDL2 around as part of the build process? Is there a place you all cont point me to that would walk me through the process and correct structural layout.
Thank you so much,
len
Raspberry Pi 5 with the 7" Pi 2 touch screen and 64bit pi OS
Create a build environment to make an application that runs on the X desktop
Building the example/demo code
