Hi everyone,
I’m trying to display an image from the Portenta X8 to an HDMI monitor via usb-c to HDMI converter. The Portenta X8 outputs video as DisplayPort to the USB-C. Can LVGL be used to accomplish this objective?
I successfully compiled the example and uploaded the sketch to the Portenta however no image is displayed.
I’m a bit new to all of this. I need a bit of guidance with this one.
This is the sketch I used (LVGL_Arduino.ino):
/*Using LVGL with Arduino requires some extra steps:
*Be sure to read the docs here: https://docs.lvgl.io/master/integration/framework/arduino.html */
#include <lvgl.h>
#include <SerialRPC.h>
#if LV_USE_TFT_ESPI
#include <TFT_eSPI.h>
/*To use the built-in examples and demos of LVGL uncomment the includes below respectively.
*You also need to copy lvgl/examples to lvgl/src/examples. Similarly for the demos lvgl/demos to lvgl/src/demos.
*Note that the lv_examples library is for LVGL v7 and you shouldn’t install it for this version (since LVGL v8)
*as the examples and demos are now part of the main LVGL library. */
//#include <examples/lv_examples.h>
//#include <demos/lv_demos.h>
/Set to your screen resolution and rotation/
#define TFT_HOR_RES 720
#define TFT_VER_RES 480
#define TFT_ROTATION LV_DISPLAY_ROTATION_0
/LVGL draw into this buffer, 1/10 screen size usually works well. The size is in bytes/
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
#if LV_USE_LOG != 0
void my_print( lv_log_level_t level, const char * buf )
LV_UNUSED(level);
Serial.println(buf);
Serial.flush();
/* LVGL calls it when a rendered image needs to copied to the display*/
void my_disp_flush( lv_display_t *disp, const lv_area_t *area, uint8_t * px_map)
/Copy px map to the area/
/*For example ("my_..." functions needs to be implemented by you)
uint32_t w = lv_area_get_width(area);
uint32_t h = lv_area_get_height(area);
my_set_window(area->x1, area->y1, w, h);
my_draw_bitmaps(px_map, w * h);
/*Call it to tell LVGL you are ready*/
lv_display_flush_ready(disp);
/Read the touchpad/
void my_touchpad_read( lv_indev_t * indev, lv_indev_data_t * data )
/*For example (“my_…” functions needs to be implemented by you)
int32_t x, y;
bool touched = my_get_touch( &x, &y );
if(!touched) {
} else {
data->point.x = x;
data->point.y = y;
/use Arduinos millis() as tick source/
static uint32_t my_tick()
return millis();
void setup()
LVGL_Arduino += String(‘V’) + lv_version_major() + “.” + lv_version_minor() + “.” + lv_version_patch();
Serial.begin( 115200 );
Serial.println( LVGL_Arduino );
/*Set a tick source so that LVGL will know how much time elapsed. */
lv_tick_set_cb(my_tick);
/* register print function for debugging */
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print );
lv_display_t * disp;
#if LV_USE_TFT_ESPI
/TFT_eSPI can be enabled lv_conf.h to initialize the display in a simple way/
disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, sizeof(draw_buf));
lv_display_set_rotation(disp, TFT_ROTATION);
#else
/Else create a display yourself/
disp = lv_display_create(TFT_HOR_RES, TFT_VER_RES);
lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_indev_t * indev = lv_indev_create();
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER); /*Touchpad should have POINTER type*/
lv_indev_set_read_cb(indev, my_touchpad_read);
/* Create a simple label
lv_obj_t *label = lv_label_create( lv_screen_active() );
lv_label_set_text( label, "Hello Arduino, I'm LVGL!" );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
* Try an example. See all the examples
* - Online: https://docs.lvgl.io/master/examples.html
* - Source codes: https://github.com/lvgl/lvgl/tree/master/examples
lv_example_btn_1();
* Or try out a demo. Don't forget to enable the demos in lv_conf.h. E.g. LV_USE_DEMO_WIDGETS
lv_demo_widgets();
void loop()
lv_timer_handler(); /* let the GUI do its work /
delay(5); / let this time pass */
After moving a few folder around I did get it to compile and it uploaded however no displayed text.
lv_conf.h is set as per instructions.
Any suggestions or links to reading material would be greatly appreciated. I’ve been having a hard time finding any solid support for this board.
Thanks for reading.
-Time
