I am using encoder for my UI, i have several buttons that create new window when clicked. Window contains lv_slider widget only. My goal is , to close window when user has finished editing. But i do not see any events that can help me.
For example, flow is :
Window is opened - > focus is moved to slider - > catching LV_EVENT_VALUE_CHANGED -> editing finished -> send enter->close window.
STM32F407 custom board
v6
I tried to catch FOCUS events and check if object is in editing or navigation mode.
see code below.
It works partially, when window is closed navigation “stuck” on button
static void add_settings_to_input_group()
lv_group_add_obj(g,sens_btn);
lv_group_add_obj(g,brightness_btn);
lv_group_add_obj(g,back_btn);
static void sens_slider_event_cb(lv_obj_t * slider, lv_event_t event)
if(event == LV_EVENT_VALUE_CHANGED) {
static char buf[5];
snprintf(buf, 5, "x%u", lv_slider_get_value(slider));
lv_label_set_text(slider_label, buf);
if(event == LV_EVENT_FOCUSED) {
if ((lv_group_get_editing(lv_obj_get_group(slider)) == false))
lv_group_remove_all_objs(g);
lv_obj_del_async(sens_win);
add_settings_to_input_group();
void draw_sensitivity_window()
sens_win = lv_win_create(settings_scr, NULL);
lv_win_set_title(sens_win, "Sensitivity");
sens_slider = lv_slider_create(sens_win, NULL);
lv_obj_set_width(sens_slider, LV_DPI * 2);
lv_obj_align(sens_slider, NULL, LV_ALIGN_CENTER, 0, -30);
lv_obj_set_event_cb(sens_slider, sens_slider_event_cb);
lv_slider_set_range(sens_slider, 0, 32);
slider_label = lv_label_create(sens_win, NULL);
lv_label_set_text(slider_label, "0");
lv_obj_set_auto_realign(slider_label, true);
lv_obj_align(slider_label, sens_slider, LV_ALIGN_OUT_TOP_MID, 0, 10);
lv_group_add_obj(g, sens_slider);
lv_group_set_editing(g,true);
void draw_settings_menu()
settings_scr = lv_obj_create(NULL, NULL);
lv_scr_load(settings_scr);
sens_btn = lv_btn_create(settings_scr, NULL);
lv_obj_align(sens_btn, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 0);
label = lv_label_create(sens_btn, NULL);
lv_label_set_text(label, "Sensitivity - x2");
lv_obj_set_size(sens_btn, 300, 30);
lv_obj_set_event_cb(sens_btn, settings_sensitivity_handler);
lv_group_add_obj(g, sens_btn);
brightness_btn = lv_btn_create(settings_scr, NULL);
lv_obj_align(brightness_btn, NULL, LV_ALIGN_IN_TOP_LEFT, 10, 32);
label = lv_label_create(brightness_btn, NULL);
lv_label_set_text(label, "Brightness - 10");
lv_obj_set_size(brightness_btn, 300, 30);
lv_obj_set_event_cb(brightness_btn, settings_brightness_handler);
lv_group_add_obj(g, brightness_btn);
https://drive.google.com/file/d/1d9A5f1jYTnlkur27tP8VEwJfFYlkxLtf/view?usp=sharing
