I’m working on a settings menu and the only input device I have is an encoder. The menu is created on a seperate screen and than switched in and out. I got sliders and buttons working and can select and actuate them using the encoder but labels are not selectable and therefore not clickable. Is this something I’m doing wrong or is this a limitation of the menu widget and labels??
Nucleo F401RE running mbed OS 6
a settings menu using labels for navigation
several examples with variing results
lv_obj_t * _menu = lv_menu_create(_menuScreen);
lv_menu_set_mode_root_back_btn(_menu, LV_MENU_ROOT_BACK_BTN_ENABLED);
v_obj_add_event_cb(_menu, btnEventHandler, LV_EVENT_CLICKED, _menu);
lv_obj_set_size(_menu, lv_disp_get_hor_res(NULL), lv_disp_get_ver_res(NULL));
lv_obj_center(_menu);
lv_obj_t * label;
lv_obj_t * cont;
lv_group_t * group = lv_group_create();
lv_group_set_default(group);
lv_indev_set_group(encoderDriver, group);
lv_obj_t * sub_1_page = lv_menu_page_create(_menu, "Page 1");
cont = lv_menu_cont_create(sub_1_page);
label = lv_label_create(cont);
lv_label_set_text(label, "Hello, I am hiding here");
lv_obj_t * sub_2_page = lv_menu_page_create(_menu, "Page 2");
cont = lv_menu_cont_create(sub_2_page);
// Create a main page
lv_obj_t * _mainPage = lv_menu_page_create(_menu, NULL);
lv_obj_t * section;
section = lv_menu_section_create(_menu);
//create_slider(section, "Kd", 0, 150, 120);
//create_slider(section, "Ki", 0, 150, 50);
//create_slider(section, "Kp", 0, 150, 80);
cont = lv_menu_cont_create(section);
lv_label_set_text(label, "Item 1");
v_menu_set_load_page_event(menu, cont, sub_1_page);
lv_label_set_text(label, "Item 2");
v_menu_set_load_page_event(menu, cont, sub_2_page);
lv_menu_set_page(_menu, _mainPage);
Counting the stepps of the encoder revealed that the focus works but the labels don’t change the style so it is merely not visible.
Maybe my problem with the seccond screen??
My expectation would have been that it “presses” the label and calls the sub page.
