The problem is that i have some images in bitmap format with a custom transparency color. After image conversion with TRUE_COLAR_CHROMA_KEY for a .bin file some images still show this color in the display. The problem is not in lvgl image converter, probrably it is the image itself (i get the images from my client), because i already have this same problem with other lib and with other image converter tool. I solved this in this other lib using more than one color as transparency. I could not found a way to this with LVGL. Can i do the same in LVGL?
MCU: TM4C1294 Cortex M4
Compiler: TI ARM CGT 19
7.11
Use multiples colors as a LV_COLOR_TRANSP.
Finally, Thanks for this great work. LVGL is one of the best graphics lib i used for embedded development (Awesome docs, code and community. Also free!). You have all my love!
