Defining multiple groups prevent keypad navigation
ESP32
8.3.9
I tried to define different groups, each with individual sets of objects (buttons) added to them. These groups should then later beeing interactively assigned to an input device.
I started with a simple project generated in Squareline 1.3.2:
there are in sum 6 buttons (two panels with 3 buttons).
In the ui.h I defined 3 groups as global constants:
extern lv_group_t *groupA;
extern lv_group_t *groupB;
extern lv_group_t *groupC;
The groups are initialized by adding those lines to the top of the ui_Screen1.c. Additionally, all objectes created subsequently are added to the groupA:
void ui_Screen1_screen_init(void)
groupA = lv_group_create();
groupB = lv_group_create();
groupC = lv_group_create();
lv_group_set_default(groupA);
created objects
So far, this works fine. The navigation with the keypad is possible.
But if I try to define for example groupB at the end of the function above (when all objects have been created), by adding
created objects
lv_group_add_obj(groupB, ui_Button1);
lv_group_add_obj(groupB, ui_Button2);
etc.
the navigation with the keypad wont work anymore, and for me its no obvious why this is the case. There is no re assignment of the input-driver, its just a simple definition of the groups.
I created this simple program with only 6 buttons after I ran into trouble with a more complex program. The global variables and groups in this program are placed in a different location, so wrode the test programm with the groups defined more close after the creation of the objects.
Best regards
GeorgS
