Multiple Displays - How to set active display
I’m trying to use 2 identical displays with different content in my project.
According to this part of the documentation I should be able to select the active display with the command lv_disp_set_default(disp)
But I can’t figure out what I should put into the place of disp for the function call.
At this section of the documentation your supposed to create display instances? lv_disp_t * disp = lv_disp_create(hor_res, ver_res)
I found a single discussion about the initialisation here. I’m using the second methode and thought this might be the problem. But infact it seems that this function call lv_disp_create() is not implemented in LVGL at all. I have scanned all files for this code but no result would come up.
So how is this supposed to work?
Ok, here is the solution.
lv_disp_t * disp1 = lv_disp_drv_register(&disp_drv1);
lv_disp_t * disp2 = lv_disp_drv_register(&disp_drv2);
lv_disp_set_default(disp2);
hi, are you using an I2C display?
I’m trying the same example with a ssd1306 display and i don’t know how to set the i2c port correctly for both of the displays. i am using the same I2C bus for both displays but with different I2C addresses
disp_drv register flush_cb and in this flush you use if disp1 addr1 or disp2 addr2
or create separate flushcb for displays.
