Mouse not working in Frame Buffer on Linux
I am building an application to run on the frame buffer on a rpi. I am able to run the demo widget slideshow but i am unable to get the mouse to work. I am using the libinput library and am using the platformio SDL project as an example of adding the mouse in with the addition of a cusor image being added and bound to the cursor. The cursor image shows in the top left of the screen. I have enabled logging and the timer for the mouse doesnt appear to be running.
Rpi4 with platformio. I had to manually link libinput in buildargs
9.1.0
I want the mouse cursor to move in the frame buffer
enabled LV_OS_PTHREAD and LV_USE_LIBINPUT
enabled logging at the info level to see if the timer executed the call back
Here is my initiation of the frame buffer as well as the mouse
  printf("LV_USE_LINUX_LIBINPUT\n");
  // https://github.com/lvgl/lv_port_linux_frame_buffer/blob/master/main.c
  const char *device = getenv_default("LV_LINUX_FBDEV_DEVICE", "/dev/fb0");
  lv_display_t *disp = lv_linux_fbdev_create();
  lv_linux_fbdev_set_file(disp, device);
  char *mousePath = lv_libinput_find_dev(LV_LIBINPUT_CAPABILITY_POINTER, true);
  lv_indev_t *mouse = lv_libinput_create(LV_INDEV_TYPE_POINTER, mousePath);
  lv_indev_set_group(mouse, lv_group_get_default());
  lv_indev_set_display(mouse, disp);
  lv_display_set_default(disp);
  LV_IMAGE_DECLARE(mouse_cursor_icon);
  lv_obj_t *cursor_obj;
  cursor_obj = lv_image_create(lv_screen_active());
  lv_image_set_src(cursor_obj, &mouse_cursor_icon);
  lv_indev_set_cursor(mouse, cursor_obj);
ok, the thread actually was running but this code “char *mousePath = lv_libinput_find_dev(LV_LIBINPUT_CAPABILITY_POINTER, true);” was not returning a mouse, it was returning vc4-hdmi-0 which apparently met the conditions of a mouse
