Minimizing RAM usage in STM32 project
I am exploring LVGL and I found that it uses many buffers like
  1. Screen-sized frame buffer
  2. minimum 1 draw buffer
  3. canvas buffer
    In my project I can’t use external RAM (SDRAM), so I want to know can I bypass draw buffers and canvas buffers and use only screen-sized frame buffer?
    What is the best method to minimize the RAM usage ?
My hardware is a stm32f429+ili9341 TFT display and I am using the LTDC RGB interface. I can also switch to the SPI interface if that helps.
Thank you for your help.
Hi @Sonia ,
Yes, this is possible. You can point LVGL’s draw buffer directly to your existing frame buffer memory to avoid allocating separate buffers. Using LV_DISPLAY_RENDER_MODE_DIRECT with a single full-screen buffer.
