Migrating from 7.5 to 8.1 - Table Cell Colours
I have a table. In 7.5 you could colour the cells. I would like to do the same in 8.1
Simulator
8.1
I would like to colour the text values of the cells
Reviewing the docs
In 7.5 I did have:
    printf("Set Colours\n");
    lv_color_t lvcolourACE = LV_COLOR_MAKE(0xF7,0x34,0x34);
    lv_obj_set_style_text_color(sensorTable, lvcolourACE, LV_TABLE_PART_CELL2);
    lv_obj_set_style_text_color(sensorTable, lv_palette_main(LV_PALETTE_LIME), LV_TABLE_PART_CELL3);
    lv_obj_set_style_text_color(sensorTable, lv_palette_main(LV_PALETTE_CYAN), LV_TABLE_PART_CELL4);
    if(strcmp("green", json_object_get_string(colour_struct)) == 0)
    	outCol = LV_TABLE_PART_CELL3;
    if(strcmp("red", json_object_get_string(colour_struct)) == 0)
    	outCol = LV_TABLE_PART_CELL2;
    if(strcmp("blue", json_object_get_string(colour_struct)) == 0)
    	outCol = LV_TABLE_PART_CELL4;
    lv_table_set_cell_type(sensorTable, arraypos, 1, outCol);
N/A
In v8 it’s a little bit more complicated but much more versatile.
See this example: Table (lv_table) — LVGL documentation
That looks like it will work when initially rendering the table.
How can i set the colour on the fly IE cell by cell?
This is what I used to have:
Thanks!
You add custom control flags like here to indicate whether the text should be red or green.
Or in the event based on the current column and row, you can see its value and the text_color accordingly.
Ah, thats going to be painful.
I’ll have to think how I can do that given I want to colour it based on the temp (thats now a string with the degree symbol)…
LV_TABLE_CELL_CTRL_CUSTOM_1/2/3/4 can be used similarly to the STYLE_1/2/3/4 in lvgl v7.
Sorry, I’m not sure I understand
This is what I had:
I’m not sure how that fits. Can you expand?
Thanks!
Alex
In the event:
        if(lv_table_has_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_1)) {
            dsc->label_dsc->color = lv_color_hex(0xff0000);
        else if(lv_table_has_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_2)) {
            dsc->label_dsc->color = lv_color_hex(0x00ff00);
On the table:
    lv_table_add_cell_ctrl(table, 1, 0, LV_TABLE_CELL_CTRL_CUSTOM_1);
    lv_table_add_cell_ctrl(table, 1, 1, LV_TABLE_CELL_CTRL_CUSTOM_2);
Result
Sorry, I must be doing something stupid.
I have:
    lv_obj_add_event_cb(sensorTable, draw_part_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
    lv_obj_add_event_cb(sensorTable, change_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
static void change_event_cb(lv_event_t * e)
    uint16_t col;
    uint16_t row;
    lv_table_get_selected_cell(obj, &row, &col);
    else if(lv_table_has_cell_ctrl(obj, row, col, LV_TABLE_CELL_CTRL_CUSTOM_3)) {
    int outCol = 0;
    	outCol = LV_TABLE_CELL_CTRL_CUSTOM_1;
    	outCol = LV_TABLE_CELL_CTRL_CUSTOM_2;
    	outCol = LV_TABLE_CELL_CTRL_CUSTOM_3;
	lv_table_add_cell_ctrl(sensorTable, arraypos, 1, outCol);
what am i doing wrong?
Thanks
Alex
Ive out some extra prints in and I dont think the callback is being called:
    printf("Change event callback called\n");
    uint16_t col;
    uint16_t row;
        printf("Set colour 1\n");
        printf("Set colour 2\n");
        printf("Set colour 3\n");
Ok, starting to make some progress.
The callback doesnt get called when the cell is updated by:
lv_table_set_cell_value(sensorTable, arraypos, 1, buffer);
via
It does get called when a cell is clicked.
However, when a cell is clicked it fails with:
Any input would be appreciated.
Thanks!
@kisvegabor any ideas?
Thanks!
I figured it out. I was using dsc in the wrong place.
Working c:
static void draw_part_event_cb(lv_event_t * e)
    lv_obj_draw_part_dsc_t * dsc = lv_event_get_param(e);
    /*If the cells are drawn...*/
    if(dsc->part == LV_PART_ITEMS) {
        uint32_t row = dsc->id /  lv_table_get_col_cnt(obj);
        uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
        /*In the first column align the texts to the right*/
        if(col == 1 || col == 2) {
            dsc->label_dsc->align = LV_TEXT_ALIGN_RIGHT;
        if(col == 3) {
            dsc->label_dsc->align = LV_TEXT_ALIGN_CENTER;
            //Green
            dsc->label_dsc->color = lv_palette_main(LV_PALETTE_LIME);
            //Red
            dsc->label_dsc->color = lv_palette_main(LV_PALETTE_RED);
            //Blue
            dsc->label_dsc->color = lv_palette_main(LV_PALETTE_CYAN);
int outCol = 0;
@elgerg, Hi, I’m new to lvgl and want to highlight values in table, may I ask how you design this GUI , which tools are you using?
thank you in advance.
Hi @anghd
There is a GUI creator, it’s called SquareLine https://squareline.io/
However if you’re using NXP there is an editor they made called GUI Guider GUI Guider | NXP Semiconductors
Personally I used neither of these, I just use Visual Studio Code and wrote my interface by hand using the LVGL widgets… It was a little painful but I did most of my work before the above editors were around. Since then it’s been a case of updating from 6 > 7 > 8…
The documentation Welcome to the documentation of LVGL! — LVGL documentation is a great starting point and there are some repos in the LVGL Github to help get you started:
https://github.com/lvgl/lv_port_pc_vscode
https://github.com/lvgl/lv_port_linux_frame_buffer
and
https://github.com/lvgl/lv_arduino
However the Arduino one looks like it hasnt been updated in a while, you might be best off installing it directly from the Arduino library manager:
It really depends on what your target is.
I hope that helps
Alex
Hi,@elgerg
thanks for you kindly guidance.
