Unfortunately that didnt work, the table still looks the same.
Could it be because itβs being updated via a timer?
sensorTable = lv_table_create(parent);
lv_obj_align_to(sensorTable, parent, LV_ALIGN_TOP_LEFT, 30, 25);
lv_obj_set_style_radius(sensorTable, 10, 0);
lv_obj_set_style_clip_corner(sensorTable, true, 0);
lv_obj_set_style_pad_top(sensorTable, 2, LV_PART_MAIN);
lv_obj_set_style_pad_bottom(sensorTable, 2, LV_PART_MAIN);
lv_obj_set_style_pad_left(sensorTable, 0, LV_PART_MAIN);
lv_obj_set_style_pad_right(sensorTable, 0, LV_PART_MAIN);
lv_table_set_col_cnt(sensorTable, 4);
lv_table_set_row_cnt(sensorTable, sizeof(screenTemps)/sizeof(struct screenTemp));
lv_table_set_col_width(sensorTable, 0, 175);
lv_table_set_col_width(sensorTable, 1, 110);
lv_table_set_col_width(sensorTable, 2, 65);
lv_table_set_col_width(sensorTable, 3, 75);
printf("Merge Cells\n");
lv_table_add_cell_ctrl(sensorTable, 0, 0, LV_TABLE_CELL_CTRL_MERGE_RIGHT);
lv_table_add_cell_ctrl(sensorTable, 0, 1, LV_TABLE_CELL_CTRL_MERGE_RIGHT);
lv_table_add_cell_ctrl(sensorTable, 0, 2, LV_TABLE_CELL_CTRL_MERGE_RIGHT);
/*Header Row*/
lv_table_set_cell_value(sensorTable, 0, 0, "Temps");
//8.1 to fix
//lv_table_set_cell_align(sensorTable, 0, 0, LV_TEXT_ALIGN_CENTER);
/*Row 1*/
for (int i = 1; i <= sizeof(screenTemps)/sizeof(struct screenTemp)+1; i++) {
lv_obj_set_style__pad_top(sensorTable, i-1, LV_STATE_DEFAULT, 2);
lv_obj_set_style__pad_bottom(sensorTable, i-1, LV_STATE_DEFAULT, 2);
lv_table_set_cell_value(sensorTable, i, 0, "");
lv_table_set_cell_value(sensorTable, i, 1, "");
//8.1 to fix
//lv_table_set_cell_align(sensorTable, i, 1, LV_TEXT_ALIGN_RIGHT);
lv_table_set_cell_value(sensorTable, i, 2, "");
//8.1 to fix
//lv_table_set_cell_align(sensorTable, i, 2, LV_TEXT_ALIGN_RIGHT);
lv_table_set_cell_value(sensorTable, i, 3, "");
#define pad 8
printf("Set Cell Padding\n");
lv_obj_set_style_pad_top(sensorTable, pad, LV_PART_ITEMS);
lv_obj_set_style_pad_bottom(sensorTable, pad, LV_PART_ITEMS);
lv_obj_set_style_pad_left(sensorTable, 2, LV_PART_ITEMS);
lv_obj_set_style_pad_right(sensorTable, 0, LV_PART_ITEMS);
lv_obj_add_event_cb(sensorTable, draw_part_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
static void draw_part_event_cb(lv_event_t * e)
lv_obj_draw_part_dsc_t * dsc = lv_event_get_param(e);
/*If the cells are drawn...*/
if(dsc->part == LV_PART_ITEMS) {
uint32_t row = dsc->id / lv_table_get_col_cnt(obj);
uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
/*In the first column align the texts to the right*/
if(col == 1 || col == 2) {
dsc->label_dsc->flag = LV_TEXT_ALIGN_RIGHT;
Tasks.c:
void updateScreen()
for (int i = 1; i <= (sizeof(screenTemps)/sizeof(struct screenTemp))+1; i++)
printTempToScreenLastSecOnly(i);
void printTempToScreenLastSecOnly(int arraypos)
int lastMessage = screenTemps[arraypos].lastLCDMsg;
if(lastMessage > 0)
int secsSinceLastMessage = (millis() /*/ 1000*/) - lastMessage;
char buf[256];
sprintf(buf, "%d", secsSinceLastMessage);
lv_table_set_cell_value(sensorTable, arraypos, 2, buf);
Result:
