I tried to build the esp32 port, but the build fails with the following error:
Including User C Module(s) from /data/mp-1.21/lv_binding_micropython/make_build
CMake Error at /data/mp-1.21/lv_binding_micropython/micropython/py/usermod.cmake:42 (include):
include requested file is a directory:
When i use command python3 make.py esp32 mpy_cross, i get the error message:
lv_binding_micropython/make.py", line 231, in read
sys.stdout.write(o_char.decode('utf-8'))
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe8 in position 0: unexpected end of data
my git commit id is dc391bd4328578bc3092eab0a61a9ad54802d98d
First, I’m brand new to lvgl, micropython, and MCUs… but was looking for a “recovery from bypass surgery project” and I got this board as it seemed like a decent platform to learn on: https://www.waveshare.com/wiki/ESP32-S3-Touch-LCD-4.3
I have been unable to get lv_micropython to compile at all:
OSX xcode command line tools
esp-idf v 4.4
lv_micropython @ master
I tried to follow the steps that I found:
git submodule update --init --recursive lib/lv_bindings
cd mpy-cross; make
cd …/ports/esp32; make BOARD=GENERIC_S3 submodules; make BOARD=GENERIC_S3
Currently the build fails in espidf.h about implicit declarations of functions. So, I don’t even know how I can get a current version of lv_micropython to see if any of the good works y’all are doing will work with this random board I got. This does appear to be an RGB board (it took me lots of research to even understand that… like I said, new to this whole world, and recovering from heart surgery.)
Thanks for all the awesome work y’all do, and hopefully one day I’ll end up with a board to play with micropython on, and some awesome graphics libs.
Thanks for everyone’s hard work, I’ve certainly been trying to understand lots of threads and git repos from @kdschlosser to try and get this to work.
I am trying to use ESP32-S3 with SPI LCD based on the ST7789 driver. Unfortunately, the source branch MicroPython_1.21.0_Update from @kdschlosser is no longer available. Is the repo GitHub - kdschlosser/lvgl_micropython: LVGL module for MicroPython its “replacement”? Has anyone had any success with similar hardware?
I successfully built an ESP32 SPIRAM image from GitHub - kdschlosser/lvgl_micropython: LVGL module for MicroPython but am having trouble with display initialization. I’m running an ILI9341 display. I have been able to use another driver for the display on the same hardware and firmware image, so the hardware itself checks out. If anyone could point me toward a simple example of how to implement that I’d appreciate it.
Now that you have the firmware built and flashed to your board, look at mpdisplay at https://github.com/bdbarnett/mpdisplay to get the drivers for ILI9341 and your touch driver. Let me know if you have any trouble.
I actually downloaded your drivers earlier today at someone else’s suggestion. I used the board_config for the esp32 s3 and ili9341. I changed out the pin assignments and commented out the touchscreen part as I don’t have one. I’m getting an error when trying to run display_simpletest.py. The error is
File “”, line 42, in
File “ili9341.py”, line 79, in init
File “busdisplay.py”, line 131, in init
TypeError: function missing 1 required positional arguments
It sounds like something is missing or out of order in your board_config.py. Please look at ili9341_eyespi_qtpy_esp32s3 and m5stack-cores3 in the board_configs directory for examples. If you still have trouble, post your board_config.py here and I’ll take a look at it. It may help me to know which ili9341 display and/or which esp32 board you have if you want to include links to those as well.
I just got it working with the lcd_bus.py from your repository. With that in the lib folder and the reference to lcd_bus in board_config changed to lib.lcd_bus, the display_simpletest.py runs. My understanding is this shouldn’t be necessary, but it is at the moment for some reason. Any thoughts on why that is?
For reference, I’m using an ODROID GO, which is a handheld gaming system based on the ESP32 with an integrated ILI9341 screen.
You are correct – you shouldn’t need to use lcd_bus.py since you are on ESP32 and have the lcd_bus C drivers from @kdschlosser already compiled in. It will be somewhat faster if you use those C drivers. I still think something is out of order in your board_config.py. Since lcd_bus and lcd_bus.py are written by different people and in different languages, they don’t behave exactly the same regarding the order of their arguments. I tried to keep lcd_bus.py as close to lcd_bus as possible, but it is also a bit more flexible than lcd_bus. If you want, please post your board_config.py and I’ll try to figure out what is happening. If you do post it, I’ll add it to mpdisplay/bus_configs as odroid_go for others to use in the future.
Thanks @kb1ujs. I don’t see anything that should be causing TypeError: function missing 1 required positional arguments on line 42. @kdschlosser may be able to help.
I haven’t updated, recompiled and flashed lvgl_micropython in a week or more. I’ll be able to do that Sunday and will get back to you if you don’t have a solution by then.
Scratch the above, I think it’s doing exactly what it’s supposed to. What I’m now suspecting is the call to display_bus.init in busdisplay.py. It appears that is the function call missing the positional argument.
The error looks like this at the moment:
File "<stdin>", line 3, in <module>
File "board_config.py", line 39, in <module>
File "ili9341.py", line 79, in __init__
File "busdisplay.py", line 131, in __init__
