How to make the only selectable element button on message box
Embedded linux
8 master (latest)
How to make the only selectable element the button/s on message box
When message box is in modal mode also the object outside (on the screen) the messagebox are selectable. On the simulator, using the mouse as input the message box modal works fine, but if TAB is pressed the selection cycle trought other objects.
/*Create a list*/
list1 = lv_list_create(lv_scr_act());
lv_obj_set_size(list1, 320, 240);
lv_obj_center(list1);
//Add buttons to the list
lv_obj_t *btn;
btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "STATUS");
lv_obj_add_event_cb(btn, event_handler, LV_EVENT_CLICKED, NULL);
btn = lv_list_add_btn(list1, LV_SYMBOL_DIRECTORY, "PARAMETERS");
btn = lv_list_add_btn(list1, LV_SYMBOL_SAVE, "NETWORK");
btn = lv_list_add_btn(list1, LV_SYMBOL_CLOSE, "SERVICE");
static const char* btns[] = { "Close", "" };
lv_obj_t* msgbox = lv_msgbox_create(NULL, "", "Login failed: wrong password.", btns, true);
lv_obj_add_event_cb(msgbox, msgbox_event_cb, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_center(msgbox);
