Hi @kisvegabor , @embeddedt
I want to clone a screen by copy all object from origin-screen
Then I display copy-screen, and change screen from copy-screen to origin-screen by slide animation.
This behavior do again in a cycle of 1 second.
After about 10s (slide 10 times), memory leak and application is stopped.
Maybe there are some data still not freed.
When delete a copy-object which is merely copied from the origin-obj, must I free anything else such as style or user data (style and user data are the data of origin-obj, I think It should not be freed)
LVGL ver 7.4.0, ver 7.10.1
Code
lv_obj_t *ori_screen, ori_img_backgound, ori_img_sub;
lv_obj_t *cp_screen, cp_img_background, cp_img_sub;
static lv_style_t style_img_backgound, style_img_sub;
void setup_origin_screen(void)
//Write codes ori_screen
ori_screen = lv_obj_create(NULL, NULL);
//Write codes ori_img_backgound
ori_img_backgound = lv_img_create(ori_screen, NULL);
//Write style LV_IMG_PART_MAIN for ori_img_backgound
lv_style_init(&style_img_backgound);
//Write style state: LV_STATE_DEFAULT for ori_img_backgound
lv_style_set_image_recolor(&style_img_backgound, LV_STATE_DEFAULT, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_image_recolor_opa(&style_img_backgound, LV_STATE_DEFAULT, 0);
lv_style_set_image_opa(&style_img_backgound, LV_STATE_DEFAULT, 255);
lv_obj_add_style(ori_img_backgound, LV_IMG_PART_MAIN, &style_img_backgound);
lv_obj_set_pos(ori_img_backgound, 0, 0);
lv_obj_set_size(ori_img_backgound, 240, 320);
lv_obj_set_click(ori_img_backgound, true);
lv_img_set_src(ori_img_backgound,&_bg_1_alpha_240x320);
lv_img_set_pivot(ori_img_backgound, 0,0);
lv_img_set_angle(ori_img_backgound, 0);
//Write codes ori_img_sub
ori_img_sub = lv_img_create(ori_screen, NULL);
//Write style LV_IMG_PART_MAIN for ori_img_sub
lv_style_init(&style_img_sub);
//Write style state: LV_STATE_DEFAULT for ori_img_sub
lv_style_set_image_recolor(&style_img_sub, LV_STATE_DEFAULT, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_image_recolor_opa(&style_img_sub, LV_STATE_DEFAULT, 0);
lv_style_set_image_opa(&style_img_sub, LV_STATE_DEFAULT, 255);
lv_obj_add_style(ori_img_sub, LV_IMG_PART_MAIN, &style_img_sub);
lv_obj_set_pos(ori_img_sub, 0, 0);
lv_obj_set_size(ori_img_sub, 100, 100);
lv_obj_set_click(ori_img_sub, true);
lv_img_set_src(ori_img_sub,&_sub_1_alpha_100x100);
lv_img_set_pivot(ori_img_sub, 0,0);
lv_img_set_angle(ori_img_sub, 0);
lv_obj_set_parent(ori_img_sub, ori_img_backgound);
lv_obj_align(ori_img_sub, ori_img_backgound, LV_ALIGN_CENTER, 0, 0);
void setup_copy_screen(void)
cp_screen = lv_obj_create(NULL, ori_screen);
cp_img_background = lv_img_create(cp_screen, ori_img_backgound);
/* ori_img_sub is child of ori_screen and ori_img_backgound */
/* So cp_img_sub will be child of both of cp_screen and cp_img_background */
/* If cp_img_sub is child of cp_img_background, and cp_img_background is child of cp_screen, */
/* When cp_screen is deleted, does cp_screen recognize cp_img_sub is a child which must be deleted? */
cp_img_sub = lv_img_create(cp_img_background, ori_img_sub);
void change_copy_to_origin(void)
lv_scr_load(cp_screen);
lv_scr_load_anim(ori_screen, LV_SCR_LOAD_ANIM_MOVE_RIGHT, 500, 0, true);
void do_cycle(void)
setup_copy_screen();
change_copy_to_origin();
void lvgl_cycle_create(void)
lv_task_create(do_cycle, 1000, LV_TASK_PRIO_MID, NULL);
