Memory leak due to switch between objects and styles
ESP32
version: 8.3.9
i want to switch between some objects and some styles based on received uart message. but after certain number of object/style switching, esp32 resets with “tg0wdt_sys_reset”. without object/style change, everything works perfect. with respect to this fact, memory leak happening.
i used esp32 lcd spi example with modifications.
void Display_Event_Handler(void)
if(Bowl_st == true)
lv_event_send(BOWL, LV_EVENT_PRESSED, NULL);
lv_event_send(END, LV_EVENT_RELEASED, NULL);
if(Bowl_st == false)
lv_event_send(BOWL, LV_EVENT_RELEASED, NULL);
if(DocA_st == true)
lv_event_send(DocA, LV_EVENT_PRESSED, NULL);
lv_event_send(DocB, LV_EVENT_RELEASED, NULL);
lv_event_send(DocC, LV_EVENT_RELEASED, NULL);
if(DocB_st == true)
lv_event_send(DocA, LV_EVENT_RELEASED, NULL);
lv_event_send(DocB, LV_EVENT_PRESSED, NULL);
if(DocC_st == true)
lv_event_send(DocC, LV_EVENT_PRESSED, NULL);
static void BOWL_event_cb(lv_event_t * e)
switch(code) {
case LV_EVENT_PRESSED:
lv_obj_add_flag(BOWL_OFF, LV_OBJ_FLAG_HIDDEN);
lv_obj_clear_flag(BOWL, LV_OBJ_FLAG_HIDDEN);
ESP_LOGI(LV_TAG, "BOWL ON");
break;
case LV_EVENT_RELEASED:
lv_obj_clear_flag(BOWL_OFF, LV_OBJ_FLAG_HIDDEN);
lv_obj_add_flag(BOWL, LV_OBJ_FLAG_HIDDEN);
break;
default:
break;
static void DocA_event_cb(lv_event_t * e)
switch(code) {
lv_obj_add_style(DocA, &style_select_doctor, 0);
ESP_LOGI(LV_TAG, "DOCTOR A");
break;
lv_obj_add_style(DocA, &style_default_doctor, 0);
break;
default:
break;
static void DocB_event_cb(lv_event_t * e)
switch(code) {
lv_obj_add_style(DocB, &style_select_doctor, 0);
ESP_LOGI(LV_TAG, "DOCTOR B");
break;
lv_obj_add_style(DocB, &style_default_doctor, 0);
break;
default:
break;
static void DocC_event_cb(lv_event_t * e)
switch(code) {
lv_obj_add_style(DocC, &style_select_doctor, 0);
ESP_LOGI(LV_TAG, "DOCTOR C");
break;
lv_obj_add_style(DocC, &style_default_doctor, 0);
break;
default:
break;
void BOWL_event(void)
BOWL = lv_img_create(lv_scr_act());
lv_img_set_src(BOWL, &Bowl);
lv_obj_align(BOWL, LV_ALIGN_TOP_RIGHT, -10, 30);
BOWL_OFF = lv_img_create(lv_scr_act());
lv_img_set_src(BOWL_OFF, &Bowl_off);
lv_obj_align(BOWL_OFF, LV_ALIGN_TOP_RIGHT, -10, 30);
lv_obj_add_event_cb(BOWL, BOWL_event_cb, LV_EVENT_ALL, NULL);
lv_obj_add_event_cb(BOWL_OFF, BOWL_event_cb, LV_EVENT_ALL, NULL);
void DOCTOR_event(void)
DocA = lv_btn_create(lv_scr_act());
lbl_A = lv_label_create(DocA);
DocB = lv_btn_create(lv_scr_act());
lbl_B = lv_label_create(DocB);
DocC = lv_btn_create(lv_scr_act());
lbl_C = lv_label_create(DocC);
lv_label_set_text_static(lbl_A, LV_SYMBOL_PLAY" DOCTOR A");
lv_obj_align(DocA, LV_ALIGN_TOP_LEFT, 0, 5);
lv_label_set_text_static(lbl_B, LV_SYMBOL_PLAY" DOCTOR B");
lv_obj_align(DocB, LV_ALIGN_TOP_LEFT, 0, 50);
lv_label_set_text_static(lbl_C, LV_SYMBOL_PLAY" DOCTOR C");
lv_obj_align(DocC, LV_ALIGN_TOP_LEFT, 0, 95);
lv_obj_add_event_cb(DocA, DocA_event_cb, LV_EVENT_ALL, NULL);
lv_obj_add_event_cb(DocB, DocB_event_cb, LV_EVENT_ALL, NULL);
lv_obj_add_event_cb(DocC, DocC_event_cb, LV_EVENT_ALL, NULL);
void MY_DISP_init(lv_disp_t *disp)
scr = lv_disp_get_scr_act(disp);
lv_style_init(&style_default_doctor);
lv_style_set_radius(&style_default_doctor, 5);
/*Make a gradient*/
lv_style_set_bg_opa(&style_default_doctor, LV_OPA_COVER);
lv_style_set_bg_color(&style_default_doctor, lv_palette_lighten(LV_PALETTE_BLUE_GREY, 1));
lv_style_set_bg_grad_color(&style_default_doctor, lv_palette_main(LV_PALETTE_GREY));
lv_style_set_bg_grad_dir(&style_default_doctor, LV_GRAD_DIR_VER);
lv_style_set_bg_main_stop(&style_default_doctor, 128);
lv_style_set_bg_grad_stop(&style_default_doctor, 192);
lv_style_set_border_color(&style_default_doctor, lv_palette_darken(LV_PALETTE_BLUE_GREY, 3));
lv_style_set_border_width(&style_default_doctor, 2);
lv_style_init(&style_select_doctor);
lv_style_set_radius(&style_select_doctor, 5);
lv_style_set_bg_opa(&style_select_doctor, LV_OPA_COVER);
lv_style_set_bg_color(&style_select_doctor, lv_palette_lighten(LV_PALETTE_BLUE, 1));
lv_style_set_bg_grad_color(&style_select_doctor, lv_palette_main(LV_PALETTE_DEEP_PURPLE));
lv_style_set_bg_grad_dir(&style_select_doctor, LV_GRAD_DIR_VER);
lv_style_set_border_color(&style_select_doctor, lv_palette_darken(LV_PALETTE_LIGHT_BLUE, 3));
lv_style_set_border_width(&style_select_doctor, 2);
lv_style_set_shadow_width(&style_select_doctor, 5);
lv_style_set_shadow_ofs_y(&style_select_doctor, 1);
lv_style_set_shadow_opa(&style_select_doctor, LV_OPA_20);
lv_style_set_text_color(&style_select_doctor, lv_color_white());
show_chair_icon();
DOCTOR_event();
void gui_task()
MY_DISP_init(disp);
while(1)
if(Changed == true)
Display_Event_Handler();
Changed = false;
lv_timer_handler();
lv_task_handler();
