Hi! I am running into an issue when alternating between two different GIFs on an active screen. I have tried getting this to work on both the ESP32 Lyra-T board and the ESP32-S3-Box by assigning callbacks to two different button presses, each time cleaning the currently active screen before displaying a GIF. Right now, I have guiTask pinned to Core 1 on the esp32, and am using a semaphore for lv_task_handler().
When alternating between two button presses, the program crashes in a somewhat random manner, sometimes crashing on the first button press and other times after having pressed either or both buttons several times. I have also gotten different backtraces and different error codes (InstrFetchProhibited, LoadProhibited, StoreProhibited, IntegerDivideByZero).
ESP32 Lyra-T & ESP32-S3-Box/gcc
9.0.0, but getting the same error with 8.3.1
I have 2 buttons on the ESP32 Lyra-T board that I use for displaying 2 different GIFs. I would like to be able to alternate between two button presses, each time cleaning the active screen and displaying the new GIF.
I have tried using semaphores/mutexes and pin the guiTask to Core 1 on the ESP32 (using a semaphore with lv_task_handler() inside guiTask). I have also tried creating 2 screens, each time loading the new screen before deleting the old one.
I have also tried displaying text instead of GIFs, and have observed the same errors.
As a last ditch effort, I went into menuconfig to set main task core affinity to “no affinity” on the Lyra-T, which helped a lot (program hardly crashed), but doing the same on the s3 box didn’t help at all, leaving me to believe I just got lucky.
Inside guiTask, which is pinned to core 1:
while (1) {
/* Delay 1 tick (assumes FreeRTOS tick is 10ms */
/* Try to take the semaphore, call lvgl related function on success */
if (pdTRUE == xSemaphoreTake(xGuiSemaphore, portMAX_DELAY)) {
lv_task_handler();
xSemaphoreGive(xGuiSemaphore);
One of the two callbacks for each button press (other call back is structured the same way):
lv_obj_t * img;
lv_obj_clean(lv_scr_act());
img = lv_gif_create(lv_scr_act());
lv_gif_set_src(img, &robot_gif);
lv_obj_align(img, LV_ALIGN_CENTER, 0, 0);
Some examples of the errors:
