I needed a pre-load animation for the progress bar in a project, and I found that no examples are available for this, so I built one by myself using a timer and changing the start/end values. Sharing it here so maybe someone else will benefit from it. If it is helpful we can put it into the examples in the docs too.
static void timer_callback(lv_timer_t * timer)
static unsigned start_value = 0;
static unsigned end_value = 0;
lv_obj_t * bar = (lv_obj_t *)(timer->user_data);
if(end_value < 100) {
lv_bar_set_start_value(bar, start_value, LV_ANIM_OFF);
lv_bar_set_value(bar, end_value++, LV_ANIM_ON);
else if(start_value < 100) {
lv_bar_set_start_value(bar, start_value++, LV_ANIM_ON);
else {
start_value = 0;
end_value = 0;
void lv_example_bar_marquee(void)
lv_obj_t * bar = lv_bar_create(lv_scr_act());
lv_obj_set_size(bar, 200, 20);
lv_obj_center(bar);
lv_timer_create(timer_callback, 10, bar);
