I want a chain of events. The idea is to be able to click on a button, have it shrink then be able to drag it left or right to perform different actions. I can’t seem to make the object draggable (hope I’m using the right term, I want to be able to “move” it with my finger (I’m using a touchscreen).
ESP32 (Espressif Dev Board), PlatformIO
7.7.0
Display and touch drivers are provided by tft_eSPI:
//touch read. this function also handles turning on the display and ignoring touches for that action
bool touchRead(lv_indev_drv_t * indev_driver, lv_indev_data_t * data) {
uint16_t touchX, touchY;
bool touched = tft.getTouch(&touchX, &touchY, 300);
if(!touched) {
return false;
} else {
//register the touch
data->state = touched ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
data->point.x = touchX;
data->point.y = touchY;
return false;
I have a long chain of events. I want to press on an object, have that object “shrink” in size (centered on the page), then be draggable horizontally.
Everything! I have the object shrinking (wasn’t easy, it involves four animations (height, width, x, y)) but I can’t work out how to make it possible to drag it after. I’m using a touchscreen, I want to be able to “swipe” it (drag it) with my finger to one side or another. I’ve tried lv_obj_set_drag(obj, true), lv_obj_set_drag_parent(obj, true) combined with lv_obj_set_drag_dir(obj, LV_DRAG_DIR_HOR). I’ve even tried disabling the existing event handler that’s used to handle the click.
void showModeSelect(lv_obj_t * obj, lv_event_t event) {
if (event == LV_EVENT_CLICKED) {
int grow_by = -60;
resizeButton(obj, grow_by);
lv_obj_set_drag(obj, true);
lv_obj_set_drag_dir(obj, LV_DRAG_DIR_HOR);
lb_obj_t * circle = lv_obj_create(scr, NULL);
lv_obj_set_size(circle, 125, 125);
lv_obj_align(circle, scr, LV_ALIGN_CENTER, 0, -30);
lv_obj_set_event_cb(circle, showModeSelect);
I’ve also m
I’ll try to upload a video later.
