M5stack core2, PlatformIO
LVGL last version.
1 frame buffer.
#include <M5Core2.h>
#include "AXP192.h"
#include <Arduino.h>
#include <lvgl.h>
#include <Wire.h>
#include <SPI.h>
#include "touch.h"
/*Read the touchpad*/
bool my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data)
TouchPoint_t pos = M5.Touch.getPressPoint();
bool touched = ( pos.x == -1 ) ? false : true;
if(!touched) {
} else {
/*Set the coordinates*/
data->point.x = pos.x;
data->point.y = pos.y;
return false; /*Return `false` because we are not buffering and no more data to read*/
/* Display flushing */
tft.startWrite();
tft.pushColors(&color_p->full, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
void setup()
M5.begin(true, true, true, true);
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation */
M5.Axp.SetLcdVoltage(2800);
M5.Axp.SetLcdVoltage(3300);
M5.Axp.SetBusPowerMode(0);
M5.Axp.SetCHGCurrent(AXP192::kCHG_190mA);
M5.Axp.SetLDOEnable(3, true);
delay(150);
M5.Axp.SetLDOEnable(3, false);
M5.Axp.SetLed(1);
delay(100);
M5.Axp.SetLed(0);
M5.Axp.SetLDOVoltage(3, 3300);
M5.Axp.SetLed(1);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 320;
disp_drv.ver_res = 240;
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
/*Create a Tab view object*/
lv_obj_t *tabview;
tabview = lv_tabview_create(lv_scr_act(), NULL);
/*Add 3 tabs (the tabs are page (lv_page) and can be scrolled*/
lv_obj_t *tab1 = lv_tabview_add_tab(tabview, "Tab 1");
lv_obj_t *tab2 = lv_tabview_add_tab(tabview, "Tab 2");
lv_obj_t *tab3 = lv_tabview_add_tab(tabview, "Tab 3");
/*Add content to the tabs*/
lv_obj_t * label = lv_label_create(NULL, NULL);
static lv_anim_path_t path_overshoot;
lv_anim_path_init(&path_overshoot);
lv_anim_path_set_cb(&path_overshoot, lv_anim_path_overshoot);
static lv_anim_path_t path_ease_out;
lv_anim_path_init(&path_ease_out);
lv_anim_path_set_cb(&path_ease_out, lv_anim_path_ease_out);
static lv_anim_path_t path_ease_in_out;
lv_anim_path_init(&path_ease_in_out);
lv_anim_path_set_cb(&path_ease_in_out, lv_anim_path_ease_in_out);
/*Gum-like button*/
static lv_style_t style_gum;
lv_style_init(&style_gum);
lv_style_set_transform_width(&style_gum, LV_STATE_PRESSED, 10);
lv_style_set_transform_height(&style_gum, LV_STATE_PRESSED, -10);
lv_style_set_value_letter_space(&style_gum, LV_STATE_PRESSED, 5);
lv_style_set_transition_path(&style_gum, LV_STATE_DEFAULT, &path_overshoot);
lv_style_set_transition_path(&style_gum, LV_STATE_PRESSED, &path_ease_in_out);
lv_style_set_transition_time(&style_gum, LV_STATE_DEFAULT, 250);
lv_style_set_transition_delay(&style_gum, LV_STATE_DEFAULT, 100);
lv_style_set_transition_prop_1(&style_gum, LV_STATE_DEFAULT, LV_STYLE_TRANSFORM_WIDTH);
lv_style_set_transition_prop_2(&style_gum, LV_STATE_DEFAULT, LV_STYLE_TRANSFORM_HEIGHT);
lv_style_set_transition_prop_3(&style_gum, LV_STATE_DEFAULT, LV_STYLE_VALUE_LETTER_SPACE);
lv_obj_t * btn1 = lv_btn_create(tab1, NULL);
lv_obj_align(btn1, NULL, LV_ALIGN_CENTER, 0, -20);
lv_obj_add_style(btn1, LV_BTN_PART_MAIN, &style_gum);
/*Instead of creating a label add a values string*/
lv_obj_set_style_local_value_str(btn1, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Gum");
/*Halo on press*/
static lv_style_t style_halo;
lv_style_init(&style_halo);
lv_style_set_transition_time(&style_halo, LV_STATE_PRESSED, 400);
lv_style_set_transition_time(&style_halo, LV_STATE_DEFAULT, 0);
lv_style_set_transition_delay(&style_halo, LV_STATE_DEFAULT, 200);
lv_style_set_outline_width(&style_halo, LV_STATE_DEFAULT, 0);
lv_style_set_outline_width(&style_halo, LV_STATE_PRESSED, 20);
lv_style_set_outline_opa(&style_halo, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_outline_opa(&style_halo, LV_STATE_FOCUSED, LV_OPA_COVER); /*Just to be sure, the theme might use it*/
lv_style_set_outline_opa(&style_halo, LV_STATE_PRESSED, LV_OPA_TRANSP);
lv_style_set_transition_prop_1(&style_halo, LV_STATE_DEFAULT, LV_STYLE_OUTLINE_OPA);
lv_style_set_transition_prop_2(&style_halo, LV_STATE_DEFAULT, LV_STYLE_OUTLINE_WIDTH);
lv_obj_t * btn2 = lv_btn_create(tab1, NULL);
lv_obj_align(btn2, NULL, LV_ALIGN_CENTER, 0, 60);
lv_obj_add_style(btn2, LV_BTN_PART_MAIN, &style_halo);
lv_obj_set_style_local_value_str(btn2, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Halo");
/*Ripple on press*/
static lv_style_t style_ripple;
lv_style_init(&style_ripple);
lv_style_set_transition_time(&style_ripple, LV_STATE_PRESSED, 300);
lv_style_set_transition_time(&style_ripple, LV_STATE_DEFAULT, 0);
lv_style_set_transition_delay(&style_ripple, LV_STATE_DEFAULT, 300);
lv_style_set_bg_opa(&style_ripple, LV_STATE_DEFAULT, 0);
lv_style_set_bg_opa(&style_ripple, LV_STATE_PRESSED, LV_OPA_80);
lv_style_set_border_width(&style_ripple, LV_STATE_DEFAULT, 0);
lv_style_set_outline_width(&style_ripple, LV_STATE_DEFAULT, 0);
lv_style_set_transform_width(&style_ripple, LV_STATE_DEFAULT, -20);
lv_style_set_transform_height(&style_ripple, LV_STATE_DEFAULT, -20);
lv_style_set_transform_width(&style_ripple, LV_STATE_PRESSED, 0);
lv_style_set_transform_height(&style_ripple, LV_STATE_PRESSED, 0);
lv_style_set_transition_path(&style_ripple, LV_STATE_DEFAULT, &path_ease_out);
lv_style_set_transition_prop_1(&style_ripple, LV_STATE_DEFAULT, LV_STYLE_BG_OPA);
lv_style_set_transition_prop_2(&style_ripple, LV_STATE_DEFAULT, LV_STYLE_TRANSFORM_WIDTH);
lv_style_set_transition_prop_3(&style_ripple, LV_STATE_DEFAULT, LV_STYLE_TRANSFORM_HEIGHT);
lv_obj_t * btn3 = lv_btn_create(tab1, NULL);
lv_obj_align(btn3, NULL, LV_ALIGN_CENTER, 0, 140);
lv_obj_add_style(btn3, LV_BTN_PART_MAIN, &style_ripple);
lv_obj_set_style_local_value_str(btn3, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Ripple");
label = lv_label_create(tab2, NULL);
lv_label_set_text(label, "Second tab");
label = lv_label_create(tab3, NULL);
lv_label_set_text(label, "Third tab");
void loop()
delay(5);
## Screenshot and/or video
