Keyboard not fitting the LCD Propoerly. I want to control the size of keyboard on my scree. I can correctly configure the width, however, not the height. LCD is 640x480 (HOR x VER).
I am using Texas DSP F28335 with CCS v10
v8.3
I want to display the keyboard on the screen properly, however, not able to set the button size smaller to that the overall keyboard height get smaller.
I tried adjusting the size of keyboard to lower height, however, the keyboard itself gets clipped. Moreover, the text on the buttons also gets dis-aligned. I have attched screenshots to both results. Only difference is the change in height (vertical resolution)
Code snippet 1. With text aligned with buttons
lv_obj_t * kb = lv_keyboard_create(lv_scr_act());
lv_obj_align(kb, LV_ALIGN_BOTTOM_MID, 0, 0);
lv_obj_set_style_base_dir(kb, LV_BASE_DIR_LTR, 0);
lv_obj_set_size(kb, 640, 380);
Code snippet 2 (Difference). With text dis-aligned with buttons
lv_obj_set_size(kb, 640, 340);
This is result of first code script
This is result of second code script
