LVGL V9 Download and display PNG on CYD
Hello everybody.
(Sorry for my english I’m a foreigner)
Using Platformio I’m almost able to display whatever widget I want but I’m struggling with a picture.
FYI lodePNG is set to 1 into lvconf.h
Just want to display a PNG picture provided by a weather forecast website.
Tried to download to LittleFS and display it => no success at all
Tried tu download to a buffer and the display it (code below) all I have is ‘PNG’ displayed like a watermark.
#include "main.h"
#include <Arduino.h>
#include <WiFi.h>
#include <esp_wifi.h>
#include <HTTPClient.h>
#include <esp32_smartdisplay.h>
#include <lvgl.h>
// URL de l’image PNG
const char *url_png = "https://prevision-meteo.ch/style/images/icon/faiblement-nuageux-big.png";
// Buffer PNG
std::vector<uint8_t> png_buf;
bool download_png(const char *url)
    HTTPClient http;
    WiFiClientSecure client;
    client.setInsecure(); // Pour HTTPS sans certificat
    if (!http.begin(client, url))
        Serial.println("HTTP begin failed");
        return false;
    int httpCode = http.GET();
    if (httpCode != 200)
        Serial.printf("HTTP GET failed, code: %d\n", httpCode);
        http.end();
        return false;
    int len = http.getSize();
    if (len <= 0)
        len = 1024 * 10; // fallback
    Serial.print("image len: ");
    Serial.println(len);
    png_buf.resize(len);
    WiFiClient *stream = http.getStreamPtr();
    int idx = 0;
    while (http.connected() && idx < len)
        while (stream->available())
            png_buf[idx++] = stream->read();
    png_buf.resize(idx); // Ajuste à taille réelle
    http.end();
    return true;
void setup()
    Serial.begin(115200);
    delay(500);
    // Connexion WiFi
    WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
    Serial.print("Connecting to WiFi");
    while (WiFi.status() != WL_CONNECTED)
        delay(500);
        Serial.print(".");
    Serial.println("\nWiFi connected!");
    // Initialisation SmartDisplay / LVGL
    smartdisplay_init();
    lv_obj_t *scr = lv_scr_act();
    // Création de l'objet image
    lv_obj_t *img = lv_img_create(scr);
    lv_obj_center(img);
    // Téléchargement PNG
    if (!download_png(url_png))
        Serial.println("PNG download failed!");
        return;
    // Affectation du buffer PNG à l'objet image
    lv_img_set_src(img, png_buf.data());
    Serial.print( (const char*)png_buf.data());
    Serial.println("PNG displayed!");
void loop()
    lv_timer_handler(); // Gestion des tâches LVGL
    delay(5);
unfortunately nono
  • MCU/MPU/Board: ESP32S3
  • **LVGL version:**9.4
Thanks for your help
Greetings,
I recommend first confirming that you can successfully load PNG images from flash storage. This helps verify that the decoder and image pipeline are working correctly. Once that is confirmed, you can move on to loading the images from a URL, since the rendering process will be the same and only the source of the data will differ.
