LVGL v9.2, LovyanGFX, SH1107 screen in I2C mode not working
Hi
I can get my SH1107 to display text by just using LovyanGFX on my ESP32 custom PCB.
I now wish to add lvgl to my project to take advantage of other features it provides. I have searched the forum and other locations on the internet with no luck, my display just sits there displaying a blank screen. Is there a trick I am over looking. I know this works…
Here is my LovyanGFX config settings
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
class LGFX : public lgfx::LGFX_Device
  lgfx::Panel_SH110x  _panel_instance; //SH1107
  lgfx::Bus_I2C       _bus_instance;
public:
  LGFX(void)
      auto cfg = _bus_instance.config();
// I2C
      cfg.i2c_port    = 0;
      cfg.freq_write  = 400000;
      cfg.freq_read   = 400000;
      cfg.pin_sda     = SDA;
      cfg.pin_scl     = SCL;
      cfg.i2c_addr    = 0x3D;
      _bus_instance.config(cfg);
      _panel_instance.setBus(&_bus_instance);
      auto cfg = _panel_instance.config();
      cfg.memory_width = 128;
      cfg.panel_width  = 128;
      cfg.memory_height = 128;
      cfg.panel_height  = 128;
      cfg.bus_shared = false;
      cfg.offset_rotation = 0;
      _panel_instance.config(cfg);
    setPanel(&_panel_instance);
my ino that I cannot get working…
/*Set to your screen resolution and rotation*/
#define TFT_HOR_RES   128
#define TFT_VER_RES   128
#define TFT_ROTATION  LV_DISPLAY_ROTATION_0
LGFX tft;
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES)
uint32_t draw_buf[DRAW_BUF_SIZE / 8];
unsigned long lastTickMillis = 0;
// Display flushing
void my_disp_flush(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) {
  lv_disp_flush_ready(disp);
// Read the touchpad
void my_touchpad_read( lv_indev_t * indev, lv_indev_data_t * data )
    // No touch screen
void display_init() {
  tft.begin();
  tft.setRotation(TFT_ROTATION);
  tft.setBrightness(255);
void ui_init() {
  static lv_style_t text_style;
  lv_style_init(&text_style);
  lv_style_set_text_font(&text_style, &lv_font_montserrat_14);
  lv_style_set_text_color(&text_style, lv_color_white());
  lv_style_set_bg_color(&text_style, lv_color_black());
  lv_obj_t *hello_world_label = lv_label_create( lv_screen_active() );
  lv_obj_add_style(hello_world_label, &text_style, 0);
  lv_obj_refresh_style(hello_world_label, LV_PART_ANY, LV_STYLE_PROP_ANY);
  lv_label_set_text(hello_world_label, "Hello world!");
  lv_obj_align(hello_world_label, LV_ALIGN_CENTER, 0, 0);
  Serial.println("UI DRAW Done");
void setup() {
  Serial.begin(115200);
  Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
  display_init();
  lv_display_t *disp = lv_display_create(TFT_HOR_RES, TFT_VER_RES);
  lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
  lv_indev_t * indev = lv_indev_create();
  lv_indev_set_read_cb(indev, my_touchpad_read);
  ui_init();
  Serial.println("Setup DONE....");
void loop() {
  unsigned int tickPeriod = millis() - lastTickMillis;
  lv_tick_inc(tickPeriod);
  lastTickMillis = millis();
Any guidance or assistance will be greatly appreciated.
Kind Regards
Paul
This request can be closed, I have moved on to a small 1.5 inch RGB OLED which is now working over SPI.
