[LVGL v9.2.2 | Portenta H7] Page Switching Issue with Dynamic Page Creation and Screen Flicker
Board:
Arduino Portenta H7
LVGL Version: v9.2.2
Arduino Core: Arduino Mbed OS Portenta Boards v4.3.1
Screen Resolution: 1024x768 (Waveshare 10.1’ display)
Description:
I’m developing a UI on the Arduino Portenta H7 using LVGL v9.2.2. The layout includes:
  • A fixed header (w:1024 h:100)
  • A fixed footer (w:1024 h:100)
  • A body container (w:1024 h:568) between the header and footer
There are 6 pages, and I use a switch_page(index) function that:
  1. Clears the existing content from the body container
  2. Creates the new page’s content dynamically based on the given index
Each page has different UI widgets (labels, LEDs , Buttons, etc.). All 6 pages are working individually, but when I switch pages, I sometimes see blank screens or screen flicker, and occasionally the screen scrolls from bottom to top unexpectedly.
Questions / Issues:
  • Is there a recommended way in LVGL v9.2.2 to destroy and recreate dynamic content inside a fixed body container for clean page switching?
  • Is lv_obj_clean(body_container) enough, or should I use lv_obj_del(body_container) and recreate it each time?
  • Could the issue be due to missing lv_refr_now() or improper invalidation of the screen?
  • Is there a best practice for lazy-loading tab/page content in a constrained system like the Portenta H7 with LVGL v9+?
Reference code:
void switch_page(uint8_t index) {
lv_obj_clean(body_container);
switch (index) {
    case 0: create_operation_page(); break;
    case 1: create_io_status_page(); break;
    case 2: create_ppc_status_page(); break;
    case 3: create_maintenance_page(); break;
    case 4: create_debug_page(); break;
    case 5: create_config_page(); break;
What you want to do is perfectly possible and should work out of the box.
To exclude driver issue, please change the bg_color o a screen every sec. It should trigger a full screen redraw. Do you see the issue in this case as well?
