With -Os option enabled in debug/release mode, LVGL v9.2.0 doesn’t compile for ARM cortex-m MCUs with GCC_ARM embedded compiler v11.3.1.
Once we disable LV_USE_LINE in lv_conf.h then it compiles with the -Os option but we will not be able to use any LINE widget. Kindly suggest or fix this issue.
thanks
sanjeev
