LVGL V8 To V9 migration guide
Hello
I had a code based on V8.4. How can I migrate code to V9.3? loads of functions has been omitted and it seems there no documentation on migration.
For example this was a working function on v8.4, however it doesnt work on v9.3, generate errors.
static void chartGrid_event_cb(lv_event_t *e)
    lv_obj_draw_part_dsc_t *dsc = lv_event_get_draw_part_dsc(e);
    if (dsc->part == LV_PART_MAIN)
        if (dsc->line_dsc == NULL || dsc->p1 == NULL || dsc->p2 == NULL)
            return;
        dsc->line_dsc->color = lv_color_mix(lv_color_hex(0x003366), lv_color_hex(0x808080), 127);
        dsc->line_dsc->width = 1;
        dsc->line_dsc->dash_gap = 3;
        dsc->line_dsc->dash_width = 3;
It would be appreciated if some one give me some help on it.
Hello, can you share the warnings and errors too?
@Tinus
Here Are the errors for example
error: request for member 'part' in something not a structure or union
  379 |     if (dsc->part == LV_PART_MAIN)
 error: request for member 'line_dsc' in something not a structure or union
  381 |         if (dsc->line_dsc == NULL || dsc->p1 == NULL || dsc->p2 == NULL)
error: request for member 'p1' in something not a structure or union
 error: request for member 'p2' in something not a structure or union
  384 |         dsc->line_dsc->color = lv_color_mix(lv_color_hex(0x003366), lv_color_hex(0x808080), 127);
  385 |         dsc->line_dsc->width = 1;
  386 |         dsc->line_dsc->dash_gap = 3;
  387 |         dsc->line_dsc->dash_width = 3;
They changed the way draw tasks work.
This is already no longer functioning.
Try
    lv_draw_task_t * draw_task = lv_event_get_draw_task(event);
    lv_draw_dsc_base_t * base_dsc = draw_task->draw_dsc;
instead.
@Tinus
How about other parts?
This function is used for making charts grids to be dashed
Same idea applies. lv_obj_draw_part_dsc_t simply no longer exists. You will have to change the drawing functions accordingly.
In case it’s still relevant you can find a v8 to v9 migration guide here:
https://docs.lvgl.io/9.0/CHANGELOG.html#migration-guide
